Front End Noise on Bumps
Old 21 Jul 2013, 10:17 pm
Default Front End Noise on Bumps
I have an 02 with 85k miles.
She is really noisy over bumps coming from the front end. Not a grinding noise, but knocks. So, I figured i would start with the struts and might as well do the back shocks. Finished that, but the noise is still there. While tires were off, I looked at the bushings on the lower control arm. They look pretty crappy, and spent.
So.... Could this be the noise?
Thanks.
Old 21 Jul 2013, 10:27 pm
randyincctx's Avatar
Question Re: Front End Noise on Bumps
Aside from the bushings on your lower control arms(which based on your desription need replacing).....How do the sway bar & end link bushings look????
Aka:~KILLER~
Old 22 Jul 2013, 06:29 am
Default Re: Front End Noise on Bumps
They look ok. By the way, I also replaced the top and bottom engine mounts (though they are are not really mounts..... more like anti movement bars).
Old 24 Jul 2013, 03:34 pm
I just ordered the sway bar and link bushings. I'm starting with those easier ones before the control arm. Hopefully, that fixes the noise.
Old 24 Jul 2013, 05:03 pm
Are the nuts on the end links on the sway bar bushings? Mine was clunking and when I checked things out the nuts on both sides for the front sway bar end links were gone!
I don't know if this is a normal Mopar thing but the front bushings our PT had a threaded insert inside of them! That means that when you take the nuts of the end links you can't slide the end link out!
You have to hold the top washer with vise grips and undo the bolt! Took me 30 minuets to figure that one out...I have never seen that done before? ( threaded end link bushings)
Old 24 Jul 2013, 09:32 pm
Yes, mine has a nut on the bottom. The bushings don't look too bad on the end links, but since I'm there, I might as well to it. I'm mainly concerned about the two middle ones.
So, hopefully it will be fairly easy. Crossing fingers...
Old 25 Jul 2013, 12:39 am
i'll second the swaybar bushings. they may look ok but they could be hard as a rock.
2016 Kia Soul Plus Black
Old 25 Jul 2013, 06:16 am
Here is a pic of the sway bar bushings. They look hard as a rock.
But, I'm afraid the real issue are the bushings in the lower Control Arm. I attached a pic. You can see the separation! Yuck!
I'm not looking forward to replacing these, but I might as well do it all at the same time.
Old 25 Jul 2013, 06:20 am
Is that what it m looks like stock? No nut on top? I thought the nuts had come off on mine, I installed nylocks on mine and the clunking went away?
When I installed the Eibach bar I discovered the OEM end link bushings are threaded so maybe they don 't need a nut? Werid...still I put nuts on it and the clunking went away? Don't know?
Old 25 Jul 2013, 07:05 am
Even though the manual says to hold the upper "retainer/nut", none of the pics actually show that nut (that I'm used to seeing).
I've attached a better pic of mine, and pics of the service manual.
I believe the "retainer/nut" is thin like a washer, but it looks like it is 12 sided. This explains the "nut" part of the description.
Odd Front end noise. pluminator Wheels, Tires, Suspension 3 12 Dec 2012 03:30 pm
front end noise wcerqua General PT Cruiser Discussions 1 05 Jun 2012 08:23 pm
front end noise Luvour04ptgt Wheels, Tires, Suspension 2 29 Sep 2010 07:45 pm
FRONT END NOISE??? help mjb457 Tech & Performance Forum 3 13 Mar 2010 12:41 pm
My front end sqeaks when I go over bumps lilooetruiser Wheels, Tires, Suspension 2 02 Dec 2009 07:23 pm
