Tire Size
  • 1 Post By 2step
Old 19 Aug 2013, 04:22 pm
Default Tire Size
Ive bought 16 rims to replace the 17s on my 03 gt, have been told i can get 205\55 16 on them without rubbing the strut any idea if i can use a 205\60 16?
Old 19 Aug 2013, 04:45 pm
cruserdad1976's Avatar
Default Re: Tire Size
I have them on a 06 on 16s and they are fine
Old 19 Aug 2013, 05:06 pm
2step's Avatar
The specs for a 205/55-16 are right at the stock circumference size, maybe a whisker smaller. The 205/60-16 is about a 1/4" more radius which puts you very close to rubbing on the strut spring perch in front. Slip your finger between to top inside of your tire and the spring perch and you will see what I mean. Tire sizes from the various tire manufacturers can vary quite a bit depending on if they round up or round down. So depending on the brand, a "big" 205/60-16 may rub while a "small" 205/60-16 wouldn't. You actually need to mount one of the ones you have in mind and try it to see. It's that close.
The back axle has more room for upsizing so no problem there.
mityqwik likes this.
Need help for the right 17" tire size! 1lowufo Wheels, Tires, Suspension 8 06 May 2005 12:32 am
Tire size?? gccruiser Turbo Wheels/Suspension/Handling 18 09 Apr 2004 07:42 pm
tire size namvetmike Wheels, Tires, Suspension 3 23 Feb 2004 04:47 pm
tire size sa4chrysler Turbo Performance 1 20 Feb 2004 01:25 pm
Tire Size scvcruzr Exterior & Interior Styling 4 02 Jul 2003 12:58 am
