Tire size w/ 18's
Old 12 May 2004, 11:40 pm
Default Tire size w/ 18's
Can one put on 18's w/ the same stock tire hieght of 205 w/out any issues in the fender well along w/ the Eiback springs? Want too raise up the front just a little. 225 is recommended. Am i correct in assuming that this tire is smaller in side wall hieght?[:I]
Old 13 May 2004, 03:37 am
If I understand your question, you want to know if you can put a 225/50-18 on the front of your PT with Eiback springs.
The 225/50-18 is approximately .4" greater sidewall height and a .5" greater wheel rim to center of hub which together would raise the front of the car .9". However, it will also change the effective gearing by 7.13% since you have a greater rolling diameter with the 225/50-18 than with the 205/50-17. 225/45-18's would be 3.6% greater and have the same sidewall height as the 205/50-17 but you would still have the .5" greater rim to center of hub measurement so the front end would be .5" greater. A 225/40-18 would have virtually the same rolling radius as the 205/50-17 since the sidewall would be .5" less to compensate for the .5" increase in rim to center of hub dimension. Not sure about the clearance issues.
Old 13 May 2004, 05:52 am
LAF LAF is offline
I dont know about clearance issues but a low profile when plus sizing wheels is going to wake your kidneys up on every tar strip you hit, my 18's on my former truck took 52 lbs of air to keep that tiny sidewal ridge. For all things to stay correct, spedo, trany sensor,ABS, Traction control, you need to plus size correctly!
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
Old 13 May 2004, 03:00 pm
Thanx for the input. Sounds like i'll just have to get used to the front clearance. Better looking w/out all that clearance between the tire and the fender well but what a pain in the butt it can be w/ it lowerd sometimes. Thanx again.
Fleming
Old 18 May 2004, 08:47 am
I haven't lowered my car yet, but I have 18x8" wheels with a 35 offset with 235/40-18 s-03's on them. No issues with the front spring perch and they ride quite nicely. I'm anticipating a bit of camber gain when I lower the car so it may be fine to the fenders.
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
Does changing the tire size affect ABS? blueberrygt Turbo Wheels/Suspension/Handling 1 16 Apr 2004 09:07 pm
18x8 rims what tire size best dfunkdj Wheels, Tires, Suspension 4 15 Apr 2004 04:04 pm
The BEST street tire in a 215/17 size CraigO Turbo Wheels/Suspension/Handling 13 16 Jul 2003 03:47 pm
tire size tom Tech & Performance Forum 3 16 Nov 2002 01:42 pm
