Strut Info
Like Tree8Likes
  #31 (permalink)
Old 22 Nov 2018, 09:37 am
rckstein's Avatar
Default Re: Strut Info
Originally Posted by Sinbad View Post
Heh you're probably right - but it's good to know they are the same part number each side.
If you fancy working your magic once more, here's a 1.6L VIN:
1C8FYN8992T230364
I'm thinking of buying this car (as I think I mentioned elsewhere) so it will be interesting to see the full spec, as well as to find out the spring info
No problem, I won't be able to get it until tomorrow.
You might want to look at the VIN label on this PT to find out what the curb weight of the total vehicle is compared to your '07.
You sure the VIN or engine size is correct?
This is from the Chrysler website and the Build Sheet says that the VIN you gave me, that PT has a 2.0L engine in it:
Looking at the Parts Catalog for your '01 & '07, they both have the same part number for the rear springs, fronts are different between the 2 years and most likely due to the different engines in each.
Sinbad likes this.
  #32 (permalink)
Old 22 Nov 2018, 11:34 pm
Sinbad's Avatar
Hmmm.... I just double checked the number I gave you, and it's spot on - edit: it looks like either me, or the seller, or both don't know what we're talking about...
Anyhoooo... can we go for it on the VIN number I gave you please?
If it *IS* a 2.0L, it's not the end of the world, except I'll have to be a bit cagey and careful on the overheating problem it has - at worst it will be a head gasket (I don't think it is for reasons I won't bore you with) which is a whole different can of worms on a 2.0L compared to a 1.6 which is a lot easier because of the timing chain....
_________________________________________
'07 2.2 CRD
  #33 (permalink)
Old 23 Nov 2018, 07:10 am
I tried that already - why do you think I'm posting here..?
Trying to find more 135 pound young ladies?
  #34 (permalink)
Old 23 Nov 2018, 09:18 pm
rckstein's Avatar
I sent you a PM with a link to the report
  #35 (permalink)
Old 02 Dec 2018, 09:05 pm
Rckstein,
Thanks so much for all that info, looks like alot of time spent!
Truly, your way would be the best for originalitysí sake. But then the dealer would be expecting you to order the OEM part from them; the costliest way to go about it.
Iím going to try lowering my tire pressures first. Sure will soften the ride, but handling will probly suffer, too.
2003 GT Turbo AT
111,111 miles +
Need tad bit of .....info :D pluminator Wheels, Tires, Suspension 4 02 Sep 2012 04:16 pm
SOME INFO PLEASE..... popkop Tech & Performance Forum 13 28 Sep 2011 03:51 pm
Need info cyann69 Exterior Accessories Forum 1 17 Aug 2011 01:43 pm
Need some info and help!!!!! A.C. Wheels, Tires, Suspension 3 19 Feb 2004 11:48 pm
EBC info ???? COP TZER Turbo Performance 4 04 Jun 2003 07:17 pm
