Brake pad part numbers for 2003 GT PT Turbo
Like Tree2Likes
Old 13 Aug 2016, 01:39 pm
Default Brake pad part numbers for 2003 GT PT Turbo
I'm having a hard time identifying the exact part numbers for front and rear .
Any other sources and identifications would be helpful
Old 13 Aug 2016, 01:54 pm
Default Re: Brake pad part numbers for 2003 GT PT Turbo
I could not get my search feature to work. I appreciate the help!
The people at the parts store look so very confused when they try to really get the right parts!
Old 13 Aug 2016, 02:35 pm
rockandroller's Avatar
What does ROCKAUTO recommend for you?
2003 CHRYSLER PT CRUISER 2.4L L4 Turbocharged Brake/Wheel Hub Parts | RockAuto
2004 'Turbo Lite'
Old 13 Aug 2016, 03:11 pm
Originally Posted by rockandroller View Post
You can also get pads at TireRack by putting in year, make & model.
Old 13 Aug 2016, 03:43 pm
These part numbers are what I find for 2003 PT Cruiser but not for PT Cruiser GT from the Chrysler parts catalog. Your best bet is to go to the dealer with your ViN number. The only reason why I am listing these numbers is in case another supplier tells you that one of these numbers will work and it might not. You need to verify with the dealer.
Front Disk Brakes
05083853AA
05086364AA
05086504AA
Drums
05018209AA SHOE KIT, Brake
Old 13 Aug 2016, 08:17 pm
Thanks everybody! I just knew if it was ordered online they might screw up a big issue
Old 22 Aug 2016, 09:48 am
2step's Avatar
When in doubt, Google Search.
Here's one vendor that I know of, there are lots more)......
https://www.modernperformance.com/ca...iser-gt-brakes
Old 22 Aug 2016, 12:15 pm
I just put a set of new front pads on mine two weeks ago. Got them at O'Reilly Auto Parts. I put the semi-metallic pads on mine. Front pads are MKD841 and rear pads when I need them will be MKD658. The emergency brake shoes part # is 643, if you want to replace them.
Handy_Cruiser likes this.
Old 29 Dec 2016, 09:08 pm
Thanks everybody ! #841 fits... Advance Auto has them ,Wear Ever was the brand.
Sorry for the delay. These pads fit very tight.... Rotor clearance is very tight ! It measured 1.067. Any ideas why would be appreciated !
Caliper piston is down, shoes slightly drag! Thanks in advance!
Old 30 Dec 2016, 08:28 am
Did you use a c-clamp to fully depress the caliper piston? I remove the master cylinder cap, and put a few shop towels under it and then depress the caliper piston with a c-clamp when changing pads. I don't buy anything from Advance. I used to work for them and consider most of their stuff as inferior to Autozone. And I don't buy anything from the Zone except batteries. I used to work for them too. So far, I've been happy with the parts I've gotten from O'Reilly and Rockauto.
looking for factory part numbers Soulman Interior Accessories Forum 2 19 Oct 2011 11:55 am
need turbo part numbers GTgirl General Turbo Discussions 6 16 Nov 2010 01:48 am
part numbers Punch General Turbo Discussions 8 19 Sep 2009 08:44 pm
Stage 2 PT Part Numbers TripleJackInGA Stage Turbo Kits 1 05 Apr 2004 10:12 am
