Help with wheel hop on 2007
Old 05 Dec 2016, 07:15 pm
Default Help with wheel hop on 2007
Driving down the interstate start to take the exit apply the brakes fairly hard to slow down for turn and it feels like the back right tire is hopping doesn't do it if I brake easy. any ideas what it could be?
thanks
Old 05 Dec 2016, 07:38 pm
rckstein's Avatar
Default Re: Help with wheel hop on 2007
Welcome to the forum
Old 06 Dec 2016, 07:57 am
Do you have rear discs or drums? If drums, then you need to remove the brake drum and see if some of the brake hardware has failed. Could possibly be a spring is weak and letting a shoe shift when you hit it hard. If the drum looks okay, get some new shoes AND all new hardware. A hardware kit doesn't cost that much and neither do shoes. Replace BOTH sides at the same time. Don't half-ass it like some folks do. You need to also look at the wheel cylinder and make sure it's not leaking. If so, replace BOTH side wheel cylinders. If ones weak, then the other isn't far behind. Oh, and welcome to the forum. Go to the new member header and introduce yourself and tell us about your PT. Thanks
Old 06 Dec 2016, 08:48 am
Welcome to the forum.
Old 06 Dec 2016, 09:15 am
Welcome to the forum!
Old 06 Dec 2016, 09:21 am
What you describe I recommend new brake pads or shoes and also the new rotors. Also a basic brake fluid replacement is in order because of the year.
While you are at the rear doing the brakes carefully examine all the other brake parts.
Chrome wheel for Alloy wheel switch advise sought Sonar Wheels, Tires, Suspension 6 27 Sep 2015 11:01 am
Groan/creaking sound when turning wheel right (front right wheel) 2k2ptc Wheels, Tires, Suspension 8 02 Sep 2012 10:52 am
WTB 2007 17x6 factory Wheel cjb15 Classifieds: Want To Buy 0 09 Dec 2011 08:58 pm
Rear Wheel vs Front Wheel OD difference moparmadness Turbo Wheels/Suspension/Handling 0 20 Sep 2011 01:23 pm
wheel skin steering wheel cover chintzgirl Interior Accessories Forum 0 23 Oct 2010 08:05 pm
