Brake noise.....Alot......Dealer says its normal.
Old 23 Jun 2004, 12:22 am
Default Brake noise.....Alot......Dealer says its normal.
Well, I dont hear most cars squeal when stopping, Just mine and old trucks. The dealer said its caused by rust and its normal for cars to do this. I asked a local brake shop and they said its the rust and ceramic brakes would do the trick.
I dont know much about them. Are they pricey? Do they stop better? Do they squeal?
Old 23 Jun 2004, 01:18 am
[V]
\"If I weren\'t your commanding officer, I\'d pick you both up, give ya a giant bear huge and make you call me daddy!\" Capt. Flowers/ Red Vs Blue.
Old 23 Jun 2004, 12:20 pm
ceramic pads work pretty good, no dust.
my brakes squeak alot but they are extremly aggressive. I never heard a peep out of the stock brakes.
Old 23 Jun 2004, 02:47 pm
Send a message via AIM to bigtommy83
Caeramics seem to have the problem of eating rotors. You'll need to do a rotor swap before a pad swap. If you have drums in the rear (this is a GT forum so probably not) get those cleaned and adjusted. But yeah, the stocks ones will squeek if they have a little "morning rust", or if they get hot like city driving with the semi metallic factory material instead of the old asbetos, they will also squeek. The squeek is a sacrifice for cleaner, safer brake pads.
\'04 GT 5-speed, Brand X, Air Force One Intake, Custom Flowmaster Exhaust (retired), SRT-4 exhaust no resonators, AGP Wastegate, Crusher Kit, Former Chrome Package, Mopar BOV, Custom Sub Box, Mopar Pillar Gauges, Hood Scoop, MBC, Stage 1, Mopar Stage 1 Springs, Hurst STS
Future Plans: Custom Intercooler Sprayer, 2-tone Paint Job
\"Hondas are like cigarettes, everyone cool smokes them\"
Old 24 Jun 2004, 12:22 am
Harder, high performance pads tend to squeal before they get up to operating temperature. Going for a performance pad may put you in this catagory.
I swapped the stockers out at 25K for Green Stuff pads and their slotted and driled discs. Stops on a dime now, but squeals when cold always.[8)]
Old 28 Jun 2004, 04:48 pm
[quoteThe dealer said its caused by rust and its normal for cars to do this. [/quote]Not sure what kind of PT you have, but any rust on the rotor would be wiped off with the first application of the brakes. Are you still on the OEM brakes? How many miles? Any other signs of bad brake wear or brake problems? Scorched rotors? Pulling to either side?
Old 30 Jun 2004, 08:35 pm
[/quote]
No, I have stock brakes with about 12k miles.
Old 10 Oct 2008, 10:22 pm
Smile Re: Brake noise.....Alot......Dealer says its normal.
I have an '03, and had the same problem. Mine would make grinding noises after starting up and would dissipate after driving for a bit.
Apparently, as I was informed, full metallics are installed at factory. So I had mine replaced with semi metallics, when it came time to have them replaced, which resolved the issue.
Hope that helps
Old 11 Oct 2008, 12:51 am
Default Re: Brake noise.....Alot......Dealer says its normal.
ummmmm, this thread is four years old.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 11 Oct 2008, 01:27 am
I was only trying to help....didn't see how old it was. Sorry
Rear brake noise... Striker Wheels, Tires, Suspension 4 04 Jun 2006 12:01 pm
New used Tires and wheels ALOT of noise why? Ctown Wheels, Tires, Suspension 8 18 May 2006 01:28 pm
Noise from suspension??? ruzz1 General PT Cruiser Discussions 5 09 Feb 2006 01:06 am
Brake kits for the Pt Gt from Moparsupercenter.com JEFF@RHJEEP Vendors & Buyers Forum 0 23 Apr 2005 01:07 pm
The Rear Brake rattle that drives me Nuts - Help! Sime Tech & Performance Forum 16 29 Apr 2004 12:40 pm
