Front wheel bearing problems
  • 1 Post By mmmadog
Old 19 May 2017, 07:25 pm
Default Front wheel bearing problems
Got the 2003 dream with the 5 speed which will matter here shortly. I cooked the driver side bearing and it spun in the spindle. Long story short the 5 speed has a specific spindle and I'm finding I might have to find one for the same year even. Thought maybe the srt spindle would work but from what I found only works for 04 and newer pt cruisers??? And than is the used piece I find going to be any better than what I have. I have new wheel bearings and hub just need the spindle or knuckle. Any help is much appreciated.
Old 20 May 2017, 12:11 am
Default Re: Front wheel bearing problems
Your post inspired me to write about what I found out when trying to figure out knuckles for my own 03 GT DC2 5spd. You can read about it here:
GT Steering knuckle differences
Old 21 May 2017, 06:57 pm
Thanks dude. Those pictures really helped. Why they went to the trouble of making so many knuckles I will never know. I even thought It might be specific to the 2003 year also. Mine has a number 489aa on it and none I have found have the same number. I found a set for a SRT 4 but the number on it is 489ab and the hole is drilled in the center. I guess I just need to find one 2003 or newer with the hole at the end like yours in the pictures. Thanks again...............Matthew
myckee likes this.
Old 21 May 2017, 09:20 pm
You are welcome. If you find a gt parts car you should find the good knuckles on it.
Wheel bearing replacement problems....need help srebik Tech & Performance Forum 7 26 Mar 2012 01:41 pm
How to tell which front wheel bearing is bad? sscanlan Tech & Performance Forum 21 13 Dec 2011 11:06 pm
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
