On my 2005 PT GT, when I get to about 50mph the steering wheel starts to shake and it gets progressively worse as the speed increases. I asked my mechanic friend to check the tires to make sure they were balanced. He said the tires look great and that he thinks it's the drive axles. I just bought the car, I'm not sure how long it has been sitting, but it only has 90,000 miles on it. The only work I have had done on it is oil change and 2 sensors replaced (cam position sensor & crank position sensor).
Does drive axles sound reasonable? How can I be sure it isn't a wheel bearing? Any help would be greatly appreciated! |
![]() Quote:
If at First You Don't Succeed - Try, Try Again |
Does is smooth out at all if you speed up or when you slow down? If so, then odds are pretty good it's either one or both axles. Do what Steve suggested. He's a pretty sharp dude.
![]() Aspire to inspire before you expire. |
Thanks guys. I will give that a try Steve and report my findings.
chuzz - it seems to get worse the faster I go, once my speed is under 50mph, it is hardly noticeable. Also, possibly related. If I am sitting still and turn the steering wheel just a couple of inches either way, I hear a slight click sound (liek the sound of a torque wrench). I also noticed tonight at a slower speed as I was cornering, I felt a dull "warble" Again, these could be totally separate issues. Thoughts? |
Classic signs of a defective half-shaft. I had a Dodge Caravan years ago that did that. Up around 50 mph it would shake the hell out of you. Speed up, it got worse, slow down, it would smooth out. Any good shop can replace it for you in under an hour. Of course, being the cheap bastard, I mean FRUGAL person that I am, I do my own work.
I am frugal as well and will do the job myself. Do you still think I should try the test that Steve suggested?
Absolutely. Just make sure that you have the PT secured and the emergency brake is set.
bad ball joints and tie rods can cause the shaking issue also.
He said he had the tires checked, but this is a good point. A car that old with 90K may have been sitting. That is a recipe for flat spots.
2003 GT 5 speed 162,000 miles |
Thread Tools | |
Display Modes | |
Front End Shakes | jkamm5k | Wheels, Tires, Suspension | 6 | 05 Feb 2014 11:44 pm |
A/C shakes car badly | moonshadow | Welcome New PT Cruiser Members | 11 | 02 Feb 2014 04:47 pm |
A/C not working and car shakes... | jcmnz24 | General PT Cruiser Discussions | 6 | 29 May 2013 08:14 pm |
08 pt shakes/shimmys | KronosGear | General PT Cruiser Discussions | 7 | 11 Aug 2011 06:46 am |
My 2004 LE shakes at 45 MPH | frances | General PT Cruiser Discussions | 3 | 04 May 2004 04:28 pm |
