Still trying to fix steering vibration
Like Tree10Likes
  #21 (permalink)
Old 10 Aug 2021, 09:47 pm
Default Re: Still trying to fix steering vibration
2 years later and I'm circling back to this issue because I still haven't solved it. I did try moving the wheels/tires from my 2001 LE to the 2005 GT, but the shaking remains. I'm back to suspecting where the CV axle connects to the intermediate shaft, but unfortunately I can't compare it to the 2001 LE because it is a non turbo and thus doesn't have the intermediate shaft.
The other thing that nobody has addressed it the clicking sounds that the steering is making. I will upload a video and see if anyone has any ideas about this.
  #22 (permalink)
Old 11 Aug 2021, 08:46 am
Here's the video I made this morning so you can hear the steering click I'm talking about https://youtu.be/uopr46wW9rg
  #23 (permalink)
Old 13 Aug 2021, 08:07 am
Check the A-arm rear bushings. It's a $3 part that's a nightmare to replace if you live in the rustbelt. If rusted, the captured nut inside the floor reinforcement likes to break loose and spin. Then you'll have to cut a hole in the floor to get at it.
  #24 (permalink)
Old 13 Aug 2021, 10:48 pm
If by A-Arm, you are referring to the control arms, I have replaced both and bushings already. It was one of the first things I tried to fix the wobble.
  #25 (permalink)
Old 14 Aug 2021, 05:45 pm
Didn't mention it in your video. Trying to find a different kind of problem I grabbed different components while causing the noise. Felt the slack.
  #26 (permalink)
Old 15 Jan 2023, 11:32 pm
2006 pt curiser vert turbo with only 80K miles
but
I have rebuilt the front suspension more than 4 times
race and street lowering kit (lasted 10 years)
ebay homemade coilovers (SHIT)
lifted tremax ( took it right out bad bad idea)
droped again with tien( waiting to finish)
plus repairs inbetween the rebuilds
I CANT STAND vibrations in the front end,
things i have found,
whel hub bearing get destroyed when up pushing on. and in literly 5k are worn out, do not buy cheap bearing EVER. do not press on bearing inner race EVER
struts get blown out easy when lowered
strut tops are suspect and bearing is a crap design causes click in the steering
axel shafts sometimes are not balanced corectly even when new espicily when buying cheap ones
my jack shaft wore out 70k and is horible vibration
clean wheel bolt mounting surface and rims use anti sieze 3 times i had a noise coing from the wheel bolts once i had inthe rear for 6 months becasue i painted the hub and the rims made indents in the paint to the metal and ended up squeeking on every revolotion even with removing wheel and reinstall,, untill its clean and flat and bare i had a sound.
i used wheel spacers with aftermarket rims and one bolt came loose HOLY crap i ripped everythaing apart a few times, finaily walked along side the car while son was driving watching the tire it was wiggeling like 1/4 inch so i went to take off the spacers to check and found one loose and one like hand tight they backed out by them self
just to be sure try a road fource balance tires can be balanced but have a hop or depression in the tread they might find it
I FEEL YOUR PAIN
joe
capevape likes this.
Vibration In Steering Wheel Only - 2006GT rvsailormm1 General Turbo Discussions 6 20 Jun 2012 08:23 pm
vibration in steering shadowsnkx Wheels, Tires, Suspension 15 25 Nov 2011 09:32 pm
Slight vibration in steering, squeaking noise coming from wheels, thud when braking thinkinboutit General PT Cruiser Discussions 6 10 Oct 2010 11:31 pm
Steering Vibration qimoves Turbo Wheels/Suspension/Handling 6 12 Jun 2005 05:45 am
Steering Wheel Vibration zzzhuh General PT Cruiser Discussions 11 31 Dec 2004 02:13 am
