PT Cruiser Forum Car Videos
Custom Wheels
Wire wheels
Old 27 Aug 2004, 11:18 am
chasfred chasfred is offline
Default Wire wheels
Where can I find wire wheels for my '04 Touring Edition with the Turbo engin. I am new to the PT's and I do not understand why so many wheels will not work with the PT's with Turbos in them.
Thanks in advance for any help I may recieve.
Charlie
'04 Turing Edition
Black and Silver
2.4L Turbo
Old 27 Aug 2004, 02:37 pm
PTGT_Boy PTGT_Boy is offline
I'm assuming your touring turbo edition has the 4 disc brake option, the calipers will require a large clearance roughly a 39mm to 35mm offset (your selection becomes more limited with those offsets).
If your looking for wire wheels, BBS from tirerack.com are the closes I can think of and they are VERY expensive rims. You can check America's Discount Tires if there is other brands you like (those tend to be less performance oriented, but cheaper and might have some wire wheels your looking for).
Old 27 Aug 2004, 02:40 pm
In addition, you might want to use the GT Cruiser as your selection for wheels, that's IF you have the 4 wheel disc option.
Old 27 Aug 2004, 04:54 pm
I only have the disk on the front wheels. Could I use wheel spacers instead of getting rims with offset?[:I]
Charlie
Gilbert, Az.
04 Touring Edition
Black & Silver
2.4L Turbo
Old 28 Aug 2004, 03:51 am
Mean Green Mean Green is online now
It's my understanding that the turbo lite has the same disc brakes as the non turbo PT. It is the GT that has the upgraded larger brakes. You can always have the dealer check the part #'s for the non turbo and turbo lite and see if they are the same.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 29 Aug 2004, 03:25 am
AlmondTurbo AlmondTurbo is offline
All the turbos have the same front disk brakes.
Old 29 Aug 2004, 04:01 am
The turbo lites do not have the same upgraded front disc brakes as the GT. The GT calipers are larger and that is why you have to use a rim with a 39mm offset.
Old 30 Aug 2004, 12:11 am
Mean Green, I stand corrected. My factory manual illustrates some differences, that don't translate on the real brake. The steel rule tells the truth. Darrell
vB code is On
Do "KLEEN WHEELS" really work??? Gary04GT Wheels, Tires, Suspension 14 26 May 2008 03:37 pm
SRT-4 Wheels on the GT blueberrygt Turbo Wheels/Suspension/Handling 3 13 Apr 2004 06:45 pm
I don't like my new wheels coolvirus Turbo Wheels/Suspension/Handling 5 05 Mar 2004 06:14 pm
Lets talk Wheels turbomangt The Detail Shop 2 05 Feb 2004 02:10 am
Wire Wheels ptturbo Turbo Wheels/Suspension/Handling 0 06 Nov 2003 02:22 pm
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  Loans | Loans | Final Fantasy OST | Online Loans | Facebook Proxy
