PT Cruiser Forum Car Videos
Custom Wheels
i installed my mopar stage II coil over shocks
  #11 (permalink)
Old 17 Oct 2004, 03:32 pm
Kirby Kirby is offline
Switching to eibach springs improves one area, but emphasizes the shortcomings in another:
The stock Tokico shocks are not up to the task of handling the rebound characteristics of a performance spring setup.
Performance Tokicos, or (my prefference) Koni adjustibles are a must do to balance out the increased rebound characteristics and shorter distances available to deal with road irregularities. I can't see the need for coil overs (and their high cost) unless you are racing and have a need to preload and adjust individual shock/springs for track performance.
Konis, and (I am sure) the performance Tokicos will bring the system back into balance at a savings of almost $1000 over the coil overs.
Coil Overs: $1200
Konis: $500
Tokico Performance: $300
If you want "the look" coil overs offer more, but for day to day driving, I think most PT owners would have a hard time seeing the $1000 difference.
P.S. - The Konis do stop "the bottoming out bump".
  #12 (permalink)
Old 18 Oct 2004, 10:44 pm
ptgtcb ptgtcb is offline
tthrift,
What, if anything, do you use from the stock front struts when you install the coil overs?
One plus with the coil overs is that you can adjust the ride height to your liking, your stuck with lowered springs and konis. I have the konis but I am starting to consider the coil overs since I do not like the stance the eibach's give my cruiser, still too high in the back.
  #13 (permalink)
Old 19 Oct 2004, 04:57 am
budrzgt budrzgt is offline
hi guys
i can help with some of the ????
the upper strut mounts have to be reused or replaced if you wish to cut down some of the labor.
when i get my mounts from tommy i will be installing the stage two kit from mopar, currently mine is all stock.
will update on the ride after install. BUD
http://www.cardomain.com/memberpage/729184/8
  #14 (permalink)
Old 27 Oct 2004, 10:07 pm
hi
ok have about 600 miles on mopar stage two kit. the ride is alot frimer and alitte road senitive. the drop was 1 3/4 in the front & 2 in the rear. drove 500 miles down hwy 101 over the weekend & it was a very nice ride at 75to80mph. i would say this kit is for someone who wants more control with a nice stance. but not for the person that might need ground clearance. BUD
  #15 (permalink)
Old 08 Nov 2004, 10:52 pm
bigguigt bigguigt is offline
tthrift,
I'm thinking of buying the mopar coilovers (mabe christmas!!).Could you tell me the front and rear drops from stock.I have Koni's now with the stock springs.There is some improvement but I need to tighten up the turns more .
thanks bigguigt
  #16 (permalink)
Old 09 Nov 2004, 04:28 am
SteelBlueGT SteelBlueGT is offline
If you ever want to sell those Konis let me know I will buy them for half of whatever you paid!![?]
  #17 (permalink)
Old 12 Nov 2004, 11:53 pm
hey bigguigt
the drop measurements i posted were from stock ride height on a 03 gt. 1 3/4inch in front & 2 inch in rear. hope this helps
BUD
  #18 (permalink)
Old 13 Nov 2004, 09:03 pm
quote:Originally posted by budrzgt
hey bigguigt
BUD
Isn't the ride height adjustable with the MoPar coil over kit(s)? That is pretty much the same drop as the eibach springs. You can not adjust it lower?
  #19 (permalink)
Old 14 Nov 2004, 05:51 am
hi ptgtcb
nope with the stage two kit the drop in the front is preset to max, all you can do is rise it. as for the back it is just new springs no adjustments. maybe with the stage three kit there is more height adjustment.
but i will say the drop & handling are very improved, and they look great too. BUD
  #20 (permalink)
Old 14 Nov 2004, 03:28 pm
hi ptgtcb
Darn, the rear is what I want to drop a little more. Do you have side pic with your suspension installed?
Thanks
vB code is On
Mopar stage 2 coil over upgrade purple people eater Turbo Wheels/Suspension/Handling 6 04 Jun 2005 03:33 am
mopar stage II coil overs are here tthrift Vendors & Buyers Forum 1 14 Sep 2004 02:18 pm
Stage 1 and mopar BOV just installed...wow RossiePT Stage Turbo Kits 3 14 Aug 2004 02:55 am
part numbers Punch General Turbo Discussions 5 13 Jan 2004 11:46 pm
Mopar Press Release - 11/04/03 skylight General Turbo Discussions 15 24 Nov 2003 05:01 am
  Home Loan | Xecuter 3 Mod Chip | Loans | Mortgage | Loans
