Rear brake kit
Old 12 Nov 2004, 10:40 am
Default Rear brake kit
While not really for the daily driver, TCE has finally finished up its rear brake kit for the SRT4, thus cross to the PT. For the show guy however this may be a fine consideration. However it does remove the parking brake seeing as it converts to a small four piston caliper assembly. When paired with the front kits it does offer some serious brake performance for open track days. Pics can be found on the SRT Forums.
Old 13 Nov 2004, 09:14 pm
You could not get a drum in hat brake rotor to work with your kit? Just wondering.
Old 16 Nov 2004, 07:56 pm
Actually, yes. I'd planned on this method from the start but the problem is that the mount plate which currently supports your caliper also acts as the mount point for all the parking brake bits inside. Adn the cable anchor.
Even this was not the end of the world. But it would require the existing plate be removed, cut down, a second plate for the new caliper be fit, and finally the old plate re fit as well. Even at THAT it's doable, but with a second 'new' mount behind the old one the drum/hat would have to be shifted out the same amount....or the hat would not seat on the shoes properly. And then we'd have about 3/8" wheel spacer built in too!
Any way I cut it, it just kept getting uglier and uglier. The current set up is a simple bolt on and only moves the wheel out a smidge. In the future I can change the bracket for the new rear caliper with the parking brake if I wish. Much more sano package.
Keep an eye out next issue or the one after that of Grassroots Motorsports where my front kit was selected for their SRT4 project car too! Should make for a nice article. Fit wise they chose the .81 rotor kit as it's the most wheel friendly over other larger kits including my track kit. No rears on it for now however.
Rear brake noise... Striker Wheels, Tires, Suspension 4 04 Jun 2006 12:01 pm
For Sale: REAR BRAKE SHOES blue Classifieds: For Sale/Trade 0 01 Aug 2005 10:15 pm
REAR DISC BRAKE UPGRADE COMPLETED blue General PT Cruiser Discussions 3 16 May 2005 11:07 am
REAR DRUM BRAKE TO DISC UPGRADE blue General PT Cruiser Discussions 18 04 May 2005 09:51 am
The Rear Brake rattle that drives me Nuts - Help! Sime Tech & Performance Forum 16 29 Apr 2004 12:40 pm
