stage 2/3 coilover??
Old 02 Feb 2005, 12:01 pm
Default stage 2/3 coilover??
has anyone installed the stage 2/3 coilover set??? and if so how is it?? is it better performance over stock gt????
Old 02 Feb 2005, 12:36 pm
those that have them have nothing but good things to say.
mopar ones dont lower the pt that much if you want to lower it go with the KW variant 1's
Old 03 Feb 2005, 04:46 am
i dont really want to lower mine..just want better handling and response.....in part...better performance...what do you think?? is it worth 1500$$
Old 03 Feb 2005, 02:11 pm
Unless you have a shop with a lift and can weigh the corners and have a in depth knowledge of setting up a coil over suspension, preloads, etc, you would be better off just getting a good set of springs. While you can, in theory, just throw a set a coilovers on the car, you will probably not improve handling unless you have a suspension guru set it up properly for you. A good set of springs and shocks/struts and sway bars is more than sufficient for most street applications. YOu didn't say if you were planning on road racing or what. Coil overs are cool but way expensive and even more expensive to have a race shop set up for you so the car is balanced. This is a process that involves intial weigh and setting, taking it out on the track for testing, bringing it back for more adjustments in response to your track test and doing it again, and again, and again if needed...
Old 03 Feb 2005, 02:49 pm
agreed.
just pop in the Tokico struts and shocks, eibach sway bars, you dont have to change the springs if you dont want it lower.
Old 03 Feb 2005, 10:54 pm
I agree with Rally. Have not tried Tokicos, but Konis are definitely great. Just installig good dampers will be a huge improvement. Also, the Mopar stage 1 springs work really well. They provide a very mild drop and significantly increased spring rates for better handling, although the ride is still pretty good. They are what the GT should have had to start with. IMHO, all the other lowering springs are for looks only, except the coil overs.
\'03 GT 5-speed. Stage 1 ECU, Konis, Stage 1 springs, Kumhos
Old 09 Feb 2005, 06:41 pm
I have a set of Stage 2 Mopar coilovers. They will be going on the car as soon as I stop working weekends... I'll post my results after the install.
They look cool!!!
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
Old 10 Feb 2005, 04:14 am
gr8, i would be very curious to hear what you find..please let me know..are you planning on doing the install??? or paying someone else???
i am interested how they perform too!!!!
Old 12 Mar 2005, 06:22 am
Sorry I haven't responded in awhile to this. Still haven't installed them yet. between the snow, salt, & non-heated garage... besides working most weekends...
Yes I am going to install them myself. I e-mailed a DC engineer he said not to worry about setup on stage 2's. they should be fine if I don't screw with them.
I know some tunner shops that i can go to if things don't feel right.
Old 12 Mar 2005, 10:32 pm
hey dark270
i have the stage 2 coilover from mopar had them in for about 5months.
this set up is pre set for height and will lower your ride 1 3/4 in front & 2inch in back.
the ride is very stiff but with a 215 50 17 tire is dose help a little. but the increase in handling is what i was after. plus the look and also that everthing is polished stainless. it looks good under the GT too.
if you plan to get a set. email tommy he had them for $1150 plus shipping.
if you go to my link page you can see the set installed. BUD
http://www.cardomain.com/memberpage/729184/8
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
Tour de Lance STAGE 7 PTRON Non-PT Discussions 0 10 Jul 2004 07:13 pm
Is Mopar Stage 1 Suspension for Real? MichaelDay Turbo Wheels/Suspension/Handling 9 06 May 2004 04:58 pm
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
Latest Stg. I Upgrade Info from MOPAR employee Steve03GT Stage Turbo Kits 292 31 Jul 2003 04:00 pm
