should i go with the 215/45r17 or the 215/50r17? the size difference is nit much (1/2") but would i get a little quicker handeling or better ride with one over the other?
If you are using stock GT wheels that are only 6" wide then you cant use the 45 series as they require 7" or bigger wheels. If you have wider wheels then by all means go to the 45 series maybe a 225/45. Remember 215mm is 215mm no matter what series you use. Just because you have a lower aspect ratio 45 vs 50 does NOT make the 215 tire any wider. Yes the lower aspect ratio gives you slightly better handling and a slightly harder ride and a little less prtection against pot hole damage to your wheel!!
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
| Largest size replacement tire for GT wheel is... | Gary04GT | Turbo Wheels/Suspension/Handling | 12 | 01 Apr 2006 10:33 pm |
| Does changing the tire size affect ABS? | blueberrygt | Turbo Wheels/Suspension/Handling | 1 | 16 Apr 2004 09:07 pm |
| 18x8 rims what tire size best | dfunkdj | Wheels, Tires, Suspension | 4 | 15 Apr 2004 04:04 pm |
| The BEST street tire in a 215/17 size | CraigO | Turbo Wheels/Suspension/Handling | 13 | 16 Jul 2003 03:47 pm |
| tire size | tom | Tech & Performance Forum | 3 | 16 Nov 2002 01:42 pm |
