PT Cruiser Forum Car Videos
Car Rims
Rear Sway Bar Measurements
Old 06 Apr 2005, 01:15 pm
SteelBlueGT SteelBlueGT is offline
Default Rear Sway Bar Measurements
Measured the ride height from ground in garage to bottom of the fender lip and the clearance from the front chin plastic piece to the ground. Rears went from 28 1/4" to 28.0". Fronts from, 27 1/2" to 27 1/4". Chin clearance stayed at 5" although I am starting to loose the chin piece. Two things could be going on the springs saged a little over time or the rear sway bar hunkered the car down some. Since I didn't notice it till the sway bar was installed I am guessing that is what did it. It is amazing that it effected the front too! Maybe it took out some slop from both front and rear suspension settings! It does appear from measurements and from my eyes that the car is slightly lowered in back but fronts look the same.
Old 06 Apr 2005, 06:31 pm
Cal Cruzer Cal Cruzer is offline
The sway bar will have on effect on ride height front or rear. The only time it comes into play is when there are twisting forces applied to it that it resists. Springs on the other hand, at least some springs, do have a tendency to settle a bit over time.
Old 08 Apr 2005, 10:51 pm
Topless in Cali Topless in Cali is offline
If you have a lot of hard miles on your PT and the springs are OEM, then it is just the springs sagging a little. The stock units on most cars driven hard sag over the miles and get real bouncey. If you've got good aftermarket springs...[:I] The rear sway does make a hugh difference, I cannot for the life of me figure out why DC took it away other than $$. I think that could account for some of the "no sales" on PT's. I did mine 3 months after I got the car due to the forums and how everyone raved about them. Thanks guys and gals.
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
vB code is On
Rear sway bar kit turbomangt Turbo Wheels/Suspension/Handling 10 05 Jul 2005 12:40 pm
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Replace/install both sway bars or just rear? im4gzs Turbo Wheels/Suspension/Handling 11 23 Feb 2004 09:11 am
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
Rear Sway Install Problem divots Turbo Wheels/Suspension/Handling 6 06 Jul 2003 01:57 pm
  Loans | Free Engineering Ebooks | Comprar vivienda Denia | Mortgages | Myspace Codes
