PT Cruiser Forum Car Videos
Car Rims
Steering Vibration
Old 07 May 2005, 10:07 pm
qimoves qimoves is offline
Default Steering Vibration
I recently purchased a 2003 turbo gt and have noticed a vibration in the steering, that starts around 65 mph. I've been back and forth with the dealership----they still have not resolved the problem. Has anyone else experienced this problem, or better yet found a solution?
J in Santa Monica
Old 08 May 2005, 05:34 am
Sci-Fi Sci-Fi is offline
Many cases in the past, the problem was traced to the Goodyear tires. Call Goodyear customer service. A lot of people had their tires replaced and balanced for free by Goodyear customer service. It's just a matter of them approving and scheduling an appointment with your local Goodyear dealer. In some cases an upgrade was approved. Since you bought a used PT, you may have to pay some of the costs.
But try the rebalancing route and see if that helps or even rotate the tires.
Old 08 May 2005, 01:51 pm
MichaelDay MichaelDay is offline
If the alignment is good and the tires have had a spin balance and you still have a vibration problem, you have two likely candidates: either a wrapped brake rotor (not typically a problem on a PT) or a defective front tire (more likely).
Old 08 May 2005, 02:47 pm
Hey thanks Sci-Fi,
I do believe there are goodyears on the car---the car is at the dealer servicing, but I'll give the tech. a call on monday relaying your advice----How did you hear about this issue and can you direct me to any of the sources that described the same problem?
Old 10 May 2005, 02:46 am
SteelBlueGT SteelBlueGT is offline
I have noticed that on certain roads I can feel a vibration in the steering wheel but that goes away as soon as the road conditions change and so far it has lasted minutes not hours. Right now with new struts and tires highway manners are at an all time best and tire vibrations just dont exist anymore at speeds up to around 85 mph!
Old 10 May 2005, 07:06 am
quote:Originally posted by qimoves
Hey thanks Sci-Fi,
There *were* several threads over at PTE about it, but it appears the threads have not been archived. PM *Big Kahuna* and he can fill you in. He got a set of upgraded tires from Goodyear.
Old 12 Jun 2005, 05:45 am
strangelove strangelove is offline
At around 80 mph I noticed a little vibration, very suttle which I figured must be due to my Goodyear tires reaching there end of life 51,808 miles to be exact. Well I recently changed my stock Goodyears to Yokohama AVS ES100's, and a alignment and no vibration what so ever. In fact if you can't get Goodyear to do the work for free, I would suggest getting some zr rated tires, they are really smooth tires.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
vB code is On
harmonic vibration rszappa1 Wheels, Tires, Suspension 17 15 Feb 2006 11:39 am
Steering Wheel Vibration zzzhuh General PT Cruiser Discussions 11 31 Dec 2004 02:13 am
Anyone that has steering problems... Please post nbr10 General Turbo Discussions 34 12 May 2004 05:17 pm
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
40-45 MPH Vibration in a new '02 PT Automatic Mopar Madness Tech & Performance Forum 14 31 Jan 2003 11:44 pm
  Cheap Car Insurance | Mobile Phone | Mortgage | Landscape Photos | Credit Card Consolidation
