Go Back   PT Cruiser Forum > Marketplace > Vendors & Buyers Forum
Digital Torque Wrench - Member Special
Old 18 Oct 2011, 10:07 am
blmw's Avatar
Default Digital Torque Wrench - Member Special - Extended for the Holiday Season
We have extended this special through the upcoming Holiday Season (until Dec. 25th). Our Wrench makes a great gift - so don't miss out !!
Brown Line Metalworks is a manufacturer of Digital Torque Wrenches. We thought they would be of interest to members of this forum, so we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: PT
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 100% of full scale (7% accuracy from 10 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25 arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 150 ft/lbs
180 1,800 in/lbs
20.3 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid till Dec 25th, and is only for the lower 48 states.
Old 12 Dec 2011, 11:36 am
blmw's Avatar
Default Re: Digital Torque Wrench - Member Special
Just a reminder - time is running out!
Old 12 Dec 2011, 03:42 pm
Nice, wish I had the $$ to afford this.
Old 12 Dec 2011, 05:33 pm
Wish I didn't already have a 3/8 and 1/2 inch set of torgues' already.
Old 22 Dec 2011, 05:06 pm
blmw's Avatar
3 days left.
2 Questions; radiator line wrench size, stop leak. FleshEater Tech & Performance Forum 3 30 Mar 2011 01:27 pm
to torque or not to torque -oil and plugs thinguy Turbo Performance 12 29 Jul 2003 05:10 pm
