Go Back   PT Cruiser Forum > Marketplace > Vendors & Buyers Forum
Winterizing Agent / Anti-Gel for Diesel Fuel Only
Old 10 Jun 2012, 05:23 am
Smile Winterizing Agent / Anti-Gel for Diesel Fuel Only
Xtreme Fuel Treatment™ contains a fuel catalyst referred to as a ‘burn rate modifier’. The burn rate modifier reduces ignition delay, which provides a significant, corresponding reduction in combustion temperature. By reducing ignition delay, the fuel reacts to combustion quicker, allowing for a longer, more complete burn. This improved combustion results in burning more of the available BTU’s of the fuel. A more complete burn improves engine performance, reduces harmful emissions significantly, and reduces fuel usage.
Enabling a more complete burn process means you use less fuel and consequently increase your trucks fuel mileage. A more complete burn process increases the available horsepower and torque, thereby improving your engine’s power. A better burn also results in less carbon buildup on engine parts and fewer emissions from the exhaust pipe. Less carbon buildup means less wear on the engine which can translate into fewer repairs and extended engine life.
XFT™ is a break-through product which produces results in four key categories:
1. Increases Gas Mileage
Reduces fuel consumption resulting in increased miles per gallon.*
2. Prolongs Engine Life & Reduces Engine Wear
A cleaner and more lubricated engine means longer engine life and reduced wear.
3. Improves Vehicle Performance & Horsepower:
Burns more of the available BTU’s in the fuel resulting in better performance.
4. Reduces Harmful Emissions & Pollutants:
Reducing harmful pollutants from the exhaust pipe results in a cleaner environment.
*Studies show a significant increase in fuel economy and engine life as well as environmental benefits. However, individual results may very depending on driving habits, age of vehicle, weather, traffic, terrain and other variances.
Money Back Guarantee
Syntek Global offers a 30 day, Money Back Guarantee (less shipping & processing charges) on Xtreme Fuel Treatment to make it convenient for you to try the product. If used correctly, XFT™ will produce results. If, after you have used the product for the minimum recommended period of time, and are not satisfied, contact Syntek Global to receive a refund.
<a href="https://www.Syntekxtremefueltreatment"> Fuel Treatment</a>
Old 10 Jun 2012, 06:39 am
Default Re: Winterizing Agent / Anti-Gel for Diesel Fuel Only
Well John, you posted in the right area of the forum. The only thing is, they don't make a diesel PT in the U.S. Maybe one of the Euro members might take advantage of your product.
Tags
fuel improvement, fuel treatment, syntek fuel treatment
2.2 diesel baz General PT Cruiser Discussions 2 29 Oct 2011 10:05 am
Diesel Fuel Injection Equipment and Turbos for sales saraliu Classifieds: For Sale/Trade 0 18 Nov 2008 01:22 am
Diesel PT Cruiser Culdee Tech & Performance Forum 9 10 Oct 2008 05:04 pm
