Go Back   PT Cruiser Forum > Marketplace > Vendors & Buyers Forum
Digital Torque Wrench - Holiday Special
Old 06 Nov 2012, 05:05 pm
blmw's Avatar
Default Digital Torque Wrench - Holiday Special
We ran this special last year, and the response was really good - so we are doing it again: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: PT
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 100% of full scale (7% accuracy from 10 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25 arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 150 ft/lbs
180 1,800 in/lbs
20.3 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid till Dec 31st, and is only for the lower 48 states.
Old 12 Nov 2012, 10:26 am
blmw's Avatar
Default Re: Digital Torque Wrench - Holiday Special
Need a great holiday gift? Well here you go!!
Old 16 Nov 2012, 11:38 am
blmw's Avatar
Get a jump on your holiday shopping!!
Old 19 Nov 2012, 11:18 am
blmw's Avatar
Don't miss out on a great wrench at a great price!!
Old 23 Nov 2012, 02:10 pm
blmw's Avatar
Black Friday is here! Get your self a great gift and buy a torque wrench!
Old 27 Nov 2012, 11:10 am
blmw's Avatar
Looking for a great torque wrench (and a great gift)? Well you found it!!
Old 03 Dec 2012, 10:41 pm
blmw's Avatar
Don't miss out on an awesome torque wrench.
Old 04 Dec 2012, 09:15 am
How often and who and what does it cost for calibration checking? I find digital equipment rather hard to get this service done? On a none digital Torque wrench I have mine checked about every two years.
Old 06 Dec 2012, 10:22 pm
blmw's Avatar
In regards to re-calibration - all torque wrenches need to be re-calibrated at some point in time. The only exception to this is the traditional Beam Style Wrenches - since you can see if the pointer is still at zero (and if it is not, you can just bend it back into position). The biggest issue with most torque wrenches (the "click" style) is that if you forget to turn the torque wrench down to its lowest setting after use, the spring will deform -and the wrench loses accuracy. This is the single biggest reason why torque wrenches become out of calibration. Our digital wrench is actually based on the traditional beam technology - so there is no need to turn the wrench down after use - and it holds its calibration very well.
However, it will at some point still need to be re-calibrated. How often is a tricky thing - since it depends on your needs / uses. Obviously, a person who is using their wrench to assemble aircraft engines will want it re-calibrated more often than someone who is using it to tighten lug-nuts on their car every few months. In general, we would recommend having it re-calibrated after 3K uses.
You would send the wrench to us in Chicago to have it re-calibrated.
BLMW
Old 07 Dec 2012, 12:07 pm
Thanks for the lesson on torque wrenches! I think I posted that same information and with more detail somewhere on this forum or maybe another?
However my question was in regards to the frequency of required calibration of this Digital Torque Wrench.
I may suggest that your analogy of an aircraft to lugs nut be re-considered? As an A & E among other qualification for responding I can say that on an aircraft as well ground operated vehicles both would need the safety of accurately torqued fasteners. So if you say 3K uses before checking calibration accuracy that would be about every *2 years for a Mechanical Service Technician and about *4-5 years for a home DIY'r?
Thanks that's really all I was asking for.
* estimating shop and DIY of fasteners needing to be torqued average use.
PT Cruiser 80 Watt Digital Amplifer 8" Subwoofer Car Speaker, Digital Crossover bubba_1952 Classifieds: For Sale/Trade 10 07 Sep 2012 04:00 pm
Digital Torque Wrench - Member Special blmw Vendors & Buyers Forum 4 22 Dec 2011 05:06 pm
2 Questions; radiator line wrench size, stop leak. FleshEater Tech & Performance Forum 3 30 Mar 2011 01:27 pm
