Go Back   PT Cruiser Forum > Marketplace > Vendors & Buyers Forum
Spark Plug (Coil-On-Plug) Boots at RockAuto.com!
Old 12 Jan 2017, 03:39 pm
RockAuto's Avatar
Smile Spark Plug (Coil-On-Plug) Boots at RockAuto.com!
"Our fun old vehicles have spark plug wires that go bad over time, but our new daily drivers have no spark plug wires and their ignition systems are maintenance free." True or False?
"Half-True" is the right answer! Most newer engines do not have spark plug wires, but they do have Spark Plug (Coil-On-Plug) Boots. A spark plug boot connects each spark plug to its individual ignition coil. Boots are often overlooked because they are out of sight. Like spark plug wires, these boots do age and may suffer internal damage from high-voltage electricity or cracking from engine heat.
RockAuto carries a wide selection of high quality brands, including boots by Standard Motor Products (SMP), ACDelco and Motorcraft, for vehicles ranging from 1990 to 2016. We also offer Ultra-Power Spark Plug (Coil-On-Plug) Boots, produced at the exact same factories as the famous brand name equivalents and with prices that can save you 10% or more compared to RockAuto's other reliably low priced parts.
Spark Plug (Coil-On-Plug) Boots are relatively easy and inexpensive to replace. You can find Spark Plug (Coil-On-Plug) Boots (along with other classic tune-up parts for older vehicles) listed under "Ignition" in the RockAuto catalog.
Old 12 Jan 2017, 09:22 pm
Default Re: Spark Plug (Coil-On-Plug) Boots at RockAuto.com!
What does this product have to do with PT Cruisers?
Old 12 Jan 2017, 10:07 pm
It has absolutely nothing to do with our PT Cruisers.
Our PTs can be modified to make the cop's work and it has been done several times over the years. It takes more time and money than its worth to do it.
Jerry
Old 13 Jan 2017, 09:30 am
RockAuto's Avatar
RockAuto sells spark plug wires and other classic tune-up parts for PT Cruisers. Thank you.
Old 13 Jan 2017, 03:10 pm
_PTGT03's Avatar
you seriously need to go find a new hobby. your attitude sucks.
Old 13 Jan 2017, 10:12 pm
You need to do something different. You should read a book to calm yourself down.
Old 23 Jan 2017, 02:56 pm
There are some comments that you might want to address on this thread?
SEE:
Goodbye Rockauto :(
Old 23 Jan 2017, 03:17 pm
RockAuto's Avatar
Thank you for bringing this to our attention. We have done our best to respond to some of the pressing questions, and set the record straight about our shipping practices.
SEE:
Goodbye Rockauto :(
C.O.P. or Coil On Plug UptownSport Tech & Performance Forum 49 23 Nov 2014 11:07 pm
Coil and spark plug wire question? Cyclone35 Tech & Performance Forum 5 26 Mar 2011 07:58 pm
Torn spark plug boots snateman Tech & Performance Forum 4 18 Mar 2011 08:28 am
Spark plug Boots stuck.... PLUMLUVPT Tech & Performance Forum 5 17 Jan 2009 01:50 pm
screaming demon coil plug gap GTCOOL Stage Turbo Kits 1 10 Jun 2004 07:15 pm
