Go Back   PT Cruiser Forum > PTCruiserLinks.com > Welcome New PT Cruiser Members
Fuel pump relay overheats
Old 17 May 2012, 07:06 pm
Default Fuel pump relay overheats
My 01 cruiser started then stalled like it ran out of fuel. i found the fuel pump relay very hot and switched it with the horn relay. The car started and ran a little while then quit. Again it overheated it, and both relays wont beep the horn now or start the pt. why are they burning up?
Old 17 May 2012, 07:13 pm
Default Re: Fuel pump relay overheats
It would be my guess your fuel pump is going bad or at the very least running continuous till the relay fails.
Old 17 May 2012, 07:46 pm
Maybe the pump itself is drawing too much current. Have you been running the fuel in the gas tank lower than 1/4 tank lately.
Old 17 May 2012, 07:58 pm
I always keep it over half full. How do i check if its going bad?
Old 17 May 2012, 09:00 pm
I don't know. Maybe someone will join in with more information.
Old 17 May 2012, 10:14 pm
UptownSport's Avatar
Ask Chromenut for section 8W and Fuel system chapter of FSM.
IIRC, there were more circuits than the fuel pump on that relay-
O2 sensors, but my a quick look at my FSM just confuses me-
there's a feed for the ASD relay, too.
It says DG/WT goes to fuel pump- get an ammeter and test for draw.
A properly functioning fuel pump actually draws very little- 3.6 amps in my Neon.
Old 18 May 2012, 07:48 pm
So i put in a replacement fuel pump today with the same results. Still overheating and frying the relay. With a new relay the car will start and run for a minute then start to run rough and die out and the relay is smoking hot.
Old 18 May 2012, 08:14 pm
I'm too exhausted to help out, haven't had but 6 hours sleep in three days, so instead I offered him a copy of the OEM service manual. Hopefully it will help him out....snnore.....zzzzzzzzzzzzzzzzzzzzzzzZZZZZZZZZ ZZZZZzzzzzzzzzzzzzzz
Old 18 May 2012, 11:31 pm
If he has a FSM- He's smarter than the rest of us.
Old 19 May 2012, 12:03 pm
I disconnected the o2 sensors and it still burns up the relay
fuel pump relay izcom2002 General PT Cruiser Discussions 7 31 Jul 2014 04:39 pm
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
Fuel Pump Relay Location 06 PT goboom2 Tech & Performance Forum 0 17 Dec 2011 03:13 pm
fuel pump help twincruiserturbos General Turbo Discussions 10 29 Jun 2010 05:53 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
