Go Back   PT Cruiser Forum > PTCruiserLinks.com > Welcome New PT Cruiser Members
transmission problem for a 2002 pt cruiser
Old 09 Oct 2017, 02:37 pm
Unhappy transmission problem for a 2002 pt cruiser
My pt crusier wont shift out of low gear ,,the shifter will move but not out of first gear ,,it works in reverse and 1st gear but it wont shift into drive ,,also the speedometer quit working at the same time. I replaced the output speed sencer,and that's not the problem ,,please help me before I spend money I don't have . Thank you CHEVY
Old 09 Oct 2017, 06:34 pm
Default Re: transmission problem for a 2002 pt cruiser
I would get a PCM scan,
Old 09 Oct 2017, 06:42 pm
to the forum.
Old 09 Oct 2017, 07:00 pm
Welcome to the forum from Pontiac, MI!
Old 09 Oct 2017, 07:01 pm
Welcome to the forum.
Anytime you have issues with your Pt Cruiser it's always a good idea to see if your engine light is on. If it is please post what the engine trouble codes are. If you don't have an OBDII Scan Tool you might try to borrow one from a friend or a neighbor.
You also might want to check your shift linkage bushings.
P.R.N.D.2.1. If you have an automatic have you checked the transmission oil level?
Transmission NO GO 2002 PT Cruiser niklndymer Tech & Performance Forum 15 27 Aug 2013 09:05 am
Help I am new here 2002 PT Cruiser Solenoid transmission pack my1sweetsarabear Welcome New PT Cruiser Members 6 01 Nov 2012 06:02 am
automatic transmission (2002 pt cruiser) javolier Tech & Performance Forum 15 20 Oct 2011 07:25 am
Respirators the Transmission. PT Cruiser 2002 javolier Tech & Performance Forum 0 22 Aug 2011 07:49 am
2002 Cruiser OBDII Problem justinbowser Tech & Performance Forum 10 27 Apr 2011 09:37 pm
