Go Back   PT Cruiser Forum > PTCruiserLinks.com > Welcome New PT Cruiser Members
Learning curve
Like Tree3Likes
  • 2 Post By Wahveed
  • 1 Post By Wahveed
Old 28 Nov 2017, 06:55 am
Default Learning curve
Hi. First forum. First Pt Cruiser. Bought an '05 convertible cheap just a couple days ago. 123K miles. Been reading up on the check engine light issues, got the error codes. P300 (multiple misfire) P304 (cylinder 4 misfire). I reset the code log. How long before I would see another error code? Is that after so many miles of driving? The previous owner claimed to have had the plugs & wires replaced recently. They looked to be newer. Haven't checked gap on plugs yet. Possibly vacuum leak? Is there an easy way to check for this? I am nowhere near being a mechanic, but I am trying to be optimistic and use this as a learning experience.
rckstein and Carnut like this.
Old 28 Nov 2017, 09:05 am
Default Re: Learning curve
Welcome to the forum. I'd suggest you check the plugs and make sure they're gapped properly and none of the ceramic is cracked. If they're okay, check your wire connections on the coil and make sure they're clean and don't have any green corrosion on them. If so, clean them and try it again. There's no telling when the codes may reappear. Too many variables to pinpoint that. While you're at it, remove the air filter box and check the ground connections on the driver side fender. A loose ground can cause multiple problems too.
Hey, hey I wanna be a rock star.
Old 28 Nov 2017, 09:09 am
Old 28 Nov 2017, 09:11 am
With the P0300 I would suggest checking your fuel pressure.
Old 28 Nov 2017, 10:11 am
Thanks, everybody! Just got my temp. plate and trying to drive a bit and see if the check engine light will come on. It seems to be running a bit better. I put some lucas oil injector cleaner in and topped the half tank with 92 octane. The seller didn't seem like the type to worry about what octane of gas to put in. I am hoping that is all it was. I will keep my fingers crossed.
VsandFords likes this.
Old 28 Nov 2017, 07:22 pm
VsandFords's Avatar
Welcome to the forum from East Texas.
Old 28 Nov 2017, 11:30 pm
Welcome to the forum from Pontiac, MI!
Old 29 Nov 2017, 06:17 pm
Welcome to the forum from Michigan.
2006 Limited n/a RIP
Old 29 Nov 2017, 07:04 pm
rckstein's Avatar
Please post some pics of your PT
'06 Touring Edition NA Automatic
160k Miles / Electric Blue Pearl
USMC '82 - '93
Bit of a lurker, looking at learning about cars. Sea_Shells Welcome New PT Cruiser Members 1 18 Jun 2015 01:37 am
New Transmission Pack Learning ? markroach Tech & Performance Forum 2 23 Jul 2012 07:09 pm
Transmission learning procedure PT_Panel General Turbo Discussions 2 09 May 2012 01:19 pm
Learning Curve AJ Tech & Performance Forum 3 13 Sep 2003 12:19 pm
2sb learning 2sb Testing 26 08 Aug 2003 02:27 am
