Go Back   PT Cruiser Forum > PTCruiserLinks.com > Welcome New PT Cruiser Members
p0304 runs rough, what is next?
Like Tree3Likes
  #11 (permalink)
Old 15 Oct 2018, 06:54 am
Default Re: p0304 runs rough, what is next?
Pull the fuel rail out, with injectors attached, set it up on top of the valve cover, disconnected the ignition coil, and have someone crank the motor while you watch the injectors spray. Firing order is the same as the spark plugs 1,3,4,2. Any abberation in the spray order or pattern could indicate a wiring fault. It sounds stupid I know, but it'll give you better idea of the fuel delivery.
chuzz likes this.
  #12 (permalink)
Old 16 Oct 2018, 01:02 am
_PTGT03's Avatar
I've done this before but you can use small plastic water bottles to catch the gas, use a timer and determine the spray volume per minute.
Tags
misfire cylinder 4, p0304
Rough Idle, Runs fine greeb69 General PT Cruiser Discussions 3 13 Apr 2012 06:45 am
PT Suddenly Runs Rough Poncho Villa Tech & Performance Forum 7 18 Dec 2010 05:03 pm
Runs rough during acceleration Reynolds1961 Tech & Performance Forum 3 06 Sep 2010 10:57 pm
'06 HO runs a bit rough at idle CruzinGT General Turbo Discussions 4 23 Mar 2010 11:20 am
