Go Back   PT Cruiser Forum > Regional Forums > Western PT Forum
Terrible intermittent idle
  • 1 Post By podo2000
Old 10 Apr 2014, 04:18 pm
Default Terrible intermittent idle
Hi folks. New here to the board, so if I mess up, my apologies in advance.
I have a 2007 pt touring edition, n/a, 1.6lt, automatic, with about 80,000 miles.
Issues: been going for about a year. really rough idle once it warms up. No issues on acceleration from a stop. Especially if I have the ac on. Also, vibration when going 55 to 60 mph, only when gas pedal depressed.
What I've done: changed plugs (gapped at .04), wires, and ignition coil (tested it and resistance was 8.3 on the primary side). Put Lucas injector cleaner and good gas several times. No vacuum leaks detected. Changed gaskets on intake when I replaced plugs, etc. didn't look bad but what the heck. Cleaned iac. No codes. Had the battery disconnected for several hours this am while double checking gap and resistance on wires. All looked good. But it ran great for a minute til I turned on the ac to check it out and it started back up again. Bummer!!
Not sure what to do next. Gotta smog this car ASAP! Thanks for your input.
Old 10 Apr 2014, 04:27 pm
cruserdad1976's Avatar
Default Re: Terrible intermittent idle
the 1.6 you must be across the pond ( not available in states)
is the fan working im not sure if this is like out PTS but the fan should be on if the AC is on
no idea why it idals rough or viberates when moving
have you checked the motor mounts???
do you have any codes???
do you haev a scanner you can read the coedes with???
maybe check the fuel pressure??
Old 10 Apr 2014, 04:51 pm
also
What is the temp gauge at? Does it go above 1/2 way?
Vibration could be engine mounts.
Old 13 Apr 2014, 03:16 pm
Thanks for the prompt reply. To answer questions
No codes
Temp doesn't go over half. I noticed the ac blows warm as soon as the idle starts acting nuts.
Motor mounts are good.
Old 13 Apr 2014, 04:23 pm
podo2000's Avatar
I had noticed on mine that I was getting a rough idle and warm air out of the ac when the high speed (a/c) fan went out. Replaced the fan and the idle issues went away.
2004 PTGT 135Kmiles
Old 13 Apr 2014, 05:54 pm
No codes
As Podo2000 found, a dead engine fan can make car idle rough, and AC blowing warm is a sure sign fan isn't coming on.
Old 14 Apr 2014, 02:21 pm
PhxPT's Avatar
My 2001 Limited has done this the last 18 months. Fixed the motor mounts in January and it appeared to have fixed the vibration, however with this unusually warm april when I turn on the A/C, at idle the hood looks like it's going to vibrate off.
Oogway - Aquamarine 2001 PT Cruiser Limited
Alpine iDA-X200 DMR headunit w/ Sirius Satellite Radio
Tags
idle, vibration
p2074 terrible idle fluctuating rpms davescales56 General PT Cruiser Discussions 2 01 Mar 2014 12:13 am
Ongoing Problem with Intermittent Rough Engine at Almost Idle NewPTCruiserInPA Tech & Performance Forum 3 10 Sep 2013 10:56 am
Intermittent Rough Idle at Start Up? NewPTCruiserInPA Tech & Performance Forum 1 31 May 2013 12:43 pm
intermittent miss at idle... luvtofish Tech & Performance Forum 9 23 May 2012 06:25 pm
2005 Turbo Rough Idle Suddenly MPG Terrible MimisMom Tech & Performance Forum 6 04 Aug 2009 06:13 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
