Go Back   PT Cruiser Forum > Regional Forums > Western PT Forum
2007 PT driver side front window gets stuck.
Old 22 Aug 2016, 11:02 pm
Default 2007 PT driver side front window gets stuck.
Hi all,
I have a 2007 PT and if I roll the front drivers side window down all the way, there is a chance it won't roll back up again unless I shut off the ignition completely, then turn it back on.
If i don't roll it down all the way it's not an issue and I can roll it back up. When it gets stuck, it does not make any sound when I try to roll it up. It just doesn't move or do anything. But if you shut the engine completely off and back on, (no need to start the engine, the accessory switch is enough) then it will roll back up freely and doesn't seem to strain or struggle.
Anyone have any ideas about this?
-Maj
Old 22 Aug 2016, 11:04 pm
Default Re: 2007 PT driver side front window gets stuck.
General rule of electrical faults: If it is weird and doesn't make sense, check for a bad ground.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 22 Aug 2016, 11:15 pm
Is this a convertible PT Cruiser?
Old 23 Aug 2016, 06:57 pm
Nope, it's not a convertible. Just the standard wagon.
I've had some grounding issues in the past so I did check the battery terminals and such and made sure everything was clean. Is there another place I should check? On the motor itself, maybe?
Any suggestions appreciated!
Tags
front, position, roll, stuck, window
HELP! DRIVER'S SIDE WINDOW WON'T GO UP golddust General PT Cruiser Discussions 9 30 Mar 2017 08:05 am
Problem with driver side window evonna_21 General PT Cruiser Discussions 5 19 Dec 2015 02:06 pm
2007 driver power window failure/window stuck down JeffLancia Tech & Performance Forum 5 30 Nov 2015 10:26 pm
Front Driver Side Power Window Stopped Working itsjusme Tech & Performance Forum 4 08 Dec 2014 01:24 pm
Driver side seatbelt stuck! Please help! Youngmaninanoldmanscar General PT Cruiser Discussions 8 22 Jan 2013 11:39 pm
