Go Back   PT Cruiser Forum > Regional Forums > Western PT Forum
California Emissions Question
Like Tree6Likes
Old 30 Sep 2018, 06:52 pm
mjb457's Avatar
Default California Emissions Question
How does a PT with a Stage 1 pass emissions in California-Smog Test -
Old 30 Sep 2018, 08:18 pm
Default Re: California Emissions Question
Can you post the results of your failed smog emissions?
Old 30 Sep 2018, 09:13 pm
Why wouldn't it?
03 Turbo AutoStick
107K
Cranny
Old 01 Oct 2018, 01:16 am
Sinbad's Avatar
Might be wrong but I thought Cali smog tests were about the same as Euro 4..?
Even my diesel is Euro 4 - you must have something seriously up the creek if you can't get a petrol PT through that.
_________________________________________
'07 2.2 CRD
Old 01 Oct 2018, 06:00 pm
mjb457's Avatar
Don't know.....
Old 01 Oct 2018, 07:19 pm
Don't know.....
Did you try to smog it yet?
Old 02 Oct 2018, 07:30 pm
mjb457's Avatar
I did not--I am just asking the California crew---my bro is in California & he said a PT with a Stage1 won't pass smog in California---(will it won't it --I was just wondering if I ever moved there--Thanks)
Old 02 Oct 2018, 07:40 pm
For the most part the biggest thing is the Stage one turns off the post or #2 HO2 sensor. That is the one after the CAT downstream. The monitors will show in readiness, HOWEVER a well trained and experience Emissions tester will know that is incorrect for a California VIN car and can fail you even if everything else appears to have passed. I could be a fine to him and the shop if it slipped by and was caught by the CARB. (California Air Resources Board) The visual aspect is part of the test.
If you do fail you could be sent to an ONLY California Emission Testing Center and YOU WILL NOT PASS with w Stage 1 as they do a complete test and inspection unlike independent smog shops.
Old 03 Oct 2018, 06:39 pm
mjb457's Avatar
Ok that stinks---how are all those hot rods driving the streets of California...in PA a car driven under 5k miles exempt from Emissions ...hmmmm
Old 03 Oct 2018, 10:13 pm
I have read some threads where the members keep the original PCM and put it back in the Pt Cruiser when they go to smog it. I am wondering if they need to change the mileage on the original PCM to keep up with the current miles the Pt
Cruiser is being driven.
Emissions solinoid delete question SPLNeon General PT Cruiser Discussions 4 20 Sep 2015 10:58 pm
S1 and emissions turbomangt Stage Turbo Kits 25 29 Apr 2010 09:03 pm
MD Emissions w Stage 1 onefastcruiser Stage Turbo Kits 6 01 Mar 2008 04:47 pm
Chrysler emissions warranty question satellite66 Tech & Performance Forum 6 07 Jun 2007 01:12 pm
S1 & Emissions? crazie.eddie Stage Turbo Kits 8 29 Aug 2004 03:39 pm
