Lowering Spring or Sway Bars?????
Old 30 Jul 2005, 07:59 pm
Default Lowering Spring or Sway Bars?????
Hi guys I'm new here so I your input would be very important to me.Should I go with springs or sway bars for better handling?I just recieved my $400.00 sign on bonus from work and thought I'll give my PT a treat{ok really it's for me[8)]}Thanks,BPC
Old 30 Jul 2005, 08:19 pm
See I'm really new to this.I have a 2005 Touring with 16" wheels.[xx(]
Old 30 Jul 2005, 09:53 pm
In '03 DCX started leaving off the rear sway bar. I'd do sway bars first. If you do sway bars they must be a matched set. No adding just the rear unless you add the rear OEM one. Eventually for beter handling you will want both and a strut bar.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 31 Jul 2005, 04:45 pm
Thank you Mean Green , I was going to get a set of Eibach sway bars and the kit to the rear one on correctly.
Old 03 Aug 2005, 01:03 am
Not going to tell you Mean Green is wrong but I put on just a rear bar (22mm) and it turned out perfect for me. I did not feel I needed to add more plow (understeer) to the front so now the rear is a little more responsive (oversteer) in a high speed turn and allows the car to rotate much more freely. I don't think mine is too unstable in a high speed turn and low speed stuff is darn near perfect now. I also have a front strut bar and nice Yoko Avid all season tires for extra grip all around. Yes, I have stayed with the stock springs cause I felt the ride was stiff enough and the springs were not a major problem for normal driving!! The ride is now very smooth and borders on luxury ride. I credit the tires for much of the new found smoothness!!
Shocks, Springs, Sway Bars Carchrism5 Wheels, Tires, Suspension 7 06 Dec 2005 09:32 pm
Sway bars quicksilverdon General PT Cruiser Discussions 11 12 Feb 2005 12:15 am
Eibach Front/Rear Sway Bars & BTG Tower Brace crazie.eddie Turbo Wheels/Suspension/Handling 22 22 Oct 2004 12:22 pm
Replace/install both sway bars or just rear? im4gzs Turbo Wheels/Suspension/Handling 11 23 Feb 2004 09:11 am
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
