Stock 17" Wheels/Tires?
Old 03 Oct 2005, 08:15 pm
Default Stock 17" Wheels/Tires?
Can't figure this out...the stock 17" tire is a 205/50. How come
the plus sizing shows 225/45??? I have 16s and what to go to 17s, what tire size?
205/50
215/50
225/45
Old 03 Oct 2005, 08:44 pm
I'm pretty sure all those you mentioned will work well and keep the speedometer and Odometer almost correct. Not sure of the exact science but the 205 (normal) and 215 (just a tab wider) will keep everything the same, but when you get bigger (225) it messes up the equation and you need to go to a smaller ratio (45) to keep it all equal. [:I]
Old 03 Oct 2005, 10:07 pm
What you want to do is keep the diameter (and circumference) of the tire/wheel the same whenever you change sizes. Changes to the diameter will effect the final drive ratio which effects the speedo, milage, power output, etc.
Here's a link to a tire size calculator to compare different sizes.
http://www.miata.net/garage/tirecalc.html
Simply put in the numbers of the stock/starting tire and the "new" preposed size. If you want a wider tire, put in the desired width and try a few different ratios to check out what happens to the diameter. You want to stay close to stock diameter.
Old 04 Oct 2005, 05:56 am
Remember the stock 17's are very narrow (6") so 205's are as wide as you can go with those wheels.[8)]
Old 04 Oct 2005, 11:38 pm
Actually, 215/50/17 fit just fine. Yokohama and other tire manufacturers also show 215 wide tires as acceptable to mount on 6" wide wheels.
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 05 Oct 2005, 09:02 am
Scott
The 215/50-17 will fit on the 6" rims but there will be a small increase in rolling radius, thus changing the parameters the engine/transmission is expecting to see. You will actually be going faster than the speedometer indicates (1 mph at 60), traveling more miles than the odometer indicates (1.6%), and slightly reducing your acceleration. All of these are within acceptable limits of a 3% change.
Old 05 Oct 2005, 04:39 pm
My Bad, of course you can upgrade to 215's that is what I did!! But the point I was trying to make is that you cant go to plus 1 or plus 2 sizing with those skinny wheels. So there is no upgrade available as far as going to a lower aspect ratio. Lost the forest cause of all those trees again. Sorry! [:I]
Old 05 Oct 2005, 10:54 pm
Thanks alot for all the info. I think I got it. Tell me if this is right...
The stock 17" wheel is 6" wide and rolls on 205/50-17s. If I go to a 7" or 7 1/2" wheel I should roll on 215/50-17s of 225/45-17s !
Old 06 Oct 2005, 04:58 am
Here is my idea go with 225/45/17 with 7" wheel width. You will gain handling with the extra width and lower aspect ratio and also stay within a .5% of the stock 17" wheel\tire rolling diameter. Depending on the tire, comfort should be pretty good too!! I feel that if you are going to buy other wheels why not get a big benefit in handling too for your money??
Old 06 Oct 2005, 03:12 pm
I was once one of those that thought 225/45-17's were too wide for the 6" wide stock wheel. Here's a shot of that combo.....
There is only a half inch of "bulge" at the sidewall and that is a nice cushion to protect the wheels from curb rash. I also had the opportunity to measure the actual width which is 6 1/4".
Make that WHEEL WIDTH = 6 1/4"
F/S Stock Rotors, Rear Seats, Shocks, Struts ptcruzin42 Classifieds: For Sale/Trade 2 11 Mar 2005 08:40 pm
As promissed, Stock PT vs Stock PT with PCM Reset Ian-PT-GT General Turbo Discussions 8 19 Jun 2004 09:57 am
What do stock 16" wheels weigh? snakepitt1 Wheels, Tires, Suspension 1 02 Jun 2004 11:28 pm
Want To Buy - Stock GT Intake and Stock BOV gsharrock Classifieds: Want To Buy 2 16 Aug 2003 12:08 pm
FS: REAL stock 16X7 chrome wheels, stock hood renichms Classifieds: For Sale/Trade 0 15 Feb 2003 03:14 pm
