fatter tires
  #11 (permalink)
Old 23 May 2003, 09:40 am
quote:Originally posted by turbomangt
hmmm interesting, when the time comes, can't I just get the same size tire with a different type of stance, like more rubber? without do all that stuff[:I]
The problem you are going to have is most all the tires in 17" diameter are performance tires that are only available in low aspect ratios. You might be able to find some 60 series in 17" but they are going to have a much larger overall diameter.
You are going to have to go to a smaller rim diameter to get the fat tire look.
Dave Clement
\'03 GT, Electric Blue
  #12 (permalink)
Old 23 May 2003, 10:39 am
quote:Originally posted by 2sb
However the reason I'm writing this is to offer a solution to "bigger tires mess up the computer". If all the tires are uniformly sized all it will do is throw off the speedometer, the odometer, and automatic's shift points. Since there are no longer physical speedometer gears in the trans to allow for tire sizes, we need another adjustment variable. What about checking for interchangeability of speed sensors with cars with larger rolling diameter tires such as the Pacifica, Concorde, minivans, etc. all front wheel drive?
I do not think that will work! The speed sensors just count revolutions. It's the ECM that translates that into distance/speed info. I know that on GM trucks you can actually access the tire diameter info in the memory of the ECM and change it for different size tires. Do not know if that is possible with the D-C ECM's
Dave Clement
  #13 (permalink)
Old 27 Jun 2003, 11:31 pm
Tire chart
http://www.miata.net/garage/tirecalc.html
  #14 (permalink)
Old 28 Jun 2003, 03:13 am
Thanks tcams76 for the link to the tire calc. It makes the tire size decision waaaaaay easier for me being able to "See It".
Help! Badyear tires strike again! SRG General PT Cruiser Discussions 40 20 Apr 2009 10:27 pm
Excellent Tires To Consider!! Gut Check General PT Cruiser Discussions 17 01 Sep 2006 04:43 am
FS: HUGE Wheels and Tires Lot ptcruzin42 Classifieds: For Sale/Trade 4 06 Jun 2006 10:41 pm
Compare tires on rims. KingKole02 Wheels, Tires, Suspension 6 15 Apr 2004 09:31 am
2003 PT Turbo 17" chrome rims and tires *MINT* GLH_TC 16V Classifieds: For Sale/Trade 2 02 Apr 2004 12:11 pm
