I've got corrosion on the bead of at least one of my '03 GT's alloys, causing a slow leak. Slow being down to 2 days. Discovered this when I took it to a tire place and they dismounted the tire. They sanded/filed the corrosion, and said it was at least a temporary fix. It's held 40 psi for a good 5 days now, but . . .
Has anyone had experience with correction of this type of corrosion? Could I hope to recover the other rims as they go bad in the same way for the longer term by sanding and/or taking a Dremel to the corrosion to smooth down the bead seal? I sure can't afford the $630 a wheel for OEM replacements. Is it really a matter of getting some brand of wheels other than the OEM ones ? Or is it a common problem across brands of chromed aluminum wheels? |
All I can tell you is that other owners have had the same problem. Some (under warranty) got new wheels from the dealer.
like crewzin said if the car is still covered bring it back to the dealership
My suggestion -
Look for folks who've upgraded & are selling off their stock wheels: http://ptenthusiasts.org/forum/showthread.php?t=52181 http://www.ptforums.com/zerothread?id=4263 http://ptcruiserworld.tenmagazines.c...bo_wheelstires Better if you post a wanted thread...
Shortly before I bought some new tires, I had a tire go flat over-night. I aired it back up and it held fine. Later, when the new tires were being mounted I saw the build up of white corrosion inside the bead of the rim and figured that was the cause.
I cleaned it up before the new tires were mounted and no leaks after 3 months but I'm still holding my breath. Only one wheel had the corrosion problems (so far). I've got the 17", GT, chrome wheels. |
| 2004 Chrome Wheel Center Trim Cap Corrosion | dpj450 | Turbo Wheels/Suspension/Handling | 7 | 04 Apr 2007 01:36 pm |
| fixing brakes and rotor | jprio | Tech & Performance Forum | 6 | 23 Sep 2006 08:59 pm |
| pt cruiser rim corrosion | Siobhan | Wheels, Tires, Suspension | 5 | 16 Nov 2005 09:50 am |
| Battery Corrosion | SteelBlueGT | General Turbo Discussions | 9 | 19 May 2005 06:47 pm |
| Head unit fixing / blanking / mounting kit | ededdneddy | Sound and Security Forum | 0 | 23 Jun 2004 09:58 pm |
