[:I]on my 2004 turbo lite auto. I have picked up a very slight vibration at aroun 70 to 75 mph. It is from the front end as I just can feel it in the steering wheel. What is strange about it is that the vibration is not steady but cycles about every few second. I am going to have the two front wheels balanced today. i have the Michelin Hydro edge so I dont think that it is a tire problem also last July I had all four balanced on the Hunter 9700 Roadforce machine. I have also noticed that when making a hard left turn like backing out of the driveway there is a knocking/clicking sound coming from the left front. Sounds like a CV jount problem. Can a bad CV joint also cause the cycling type vibration also? any other Pt owners have or had this type of vibration in the past?
CV joints can cause a cyclic vibration. I'd have the balance checked first, then make sure the lug nuts are torqued properly. The main causes of any vibration are the rotating components. Get it balanced, torqued and check rotor trueness. This will uncover 90% of the problems. If it still is there, check tire concentricity, driveline components (CV joints and axles) and the components that hold the wheels in position. This would include the suspension and steering. That should cover anything that could cause this problem. Good Luck
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
I plan on getting it balanced on friday. Even if this takes care of the vibration I still plan on taking it into the dealer for the cv knocking/clicking sound. I have 32,000 miles on my 2004 so it has the full warranty....yet.....thanks for you comments...
I know you said you were getting a fresh balance but be sure to rotate also. If you still "feel" the same problem after a balance/rotate, then you would need to check the CV joints, brakes, axels, etc.
Good Point....Thanks
let us know what happens, dont let the dealership push you around take them for a ride and show them .
well I had the two front tires rebalanced on the hunter roadforce and still had the vibration...rotated the front to the back...still have the sound....time to take it into the dealer....i know that one of the cv joints is bad because of the clicking/thunping sound when making a sharp left turn. that may be the viberation also..or maybe a wheel bearing starting to go bad...o well I have 33345 mile on it so it has the full warranty yet...
Well I took it into the dealer today and they said the right outer cv joint is bad. They do not repair them...they just order a new complete axle for that side and replace it....
did the same thing to my 03 turbo car didnt even have 10,000 miles and they were shot!!
| vibration causing dash to rattle | Easymover | Tech & Performance Forum | 3 | 26 Jan 2006 07:34 pm |
| 40 to 60 mph Vibration Update fixed | gtbright | General Turbo Discussions | 5 | 05 Sep 2005 06:51 pm |
| Steering Vibration | qimoves | Turbo Wheels/Suspension/Handling | 6 | 12 Jun 2005 05:45 am |
| 40-45 MPH Vibration in a new '02 PT Automatic | Mopar Madness | Tech & Performance Forum | 14 | 31 Jan 2003 11:44 pm |
| aftermarket rim vibration | rumrunnerx | Tech & Performance Forum | 11 | 10 Jun 2002 11:29 am |
