PT Cruiser Forum Car Videos
Custom Wheels
NEED HELP !
Old 28 Feb 2006, 10:14 pm
ptTurbo528 ptTurbo528 is offline
Send a message via AIM to ptTurbo528
Default NEED HELP !
Ok i have read in other forums on here that some guys were upgrading tire size from a stock 205/50/17...My question is will a 215/50/17 size tire fit on my GT if it lowered its droped 2in in the front and 1.5in in the rear..Will i have a problem with clearance if i go to this wider tire ? Im not quite sure, but i dont think i will have a problem but i need help and i would like to go wider since the car is lower and i have some other suspension mods done so im trying to get a little more handling out of it what do you guys think NEED INPUT DESPERATLY ! Thanks guys for the help ... Brian
Old 01 Mar 2006, 12:01 am
TurboCruiser13 TurboCruiser13 is offline
Send a message via AIM to TurboCruiser13
215s will fit quite easily on the GT wheels and the lowering is not an issue unless you're goin with much wider tires than that. Anything greater than 235s and you run the risk of rubbing on the strut so watch out for that. But 215s will do the trick
Old 11 Apr 2006, 08:58 pm
bobs turbo pt bobs turbo pt is offline
if you put the tires on post some pics !![?]
vB code is On
  Debt Loans | Direct TV | Loans | Debt | Loans
