PT Cruiser Forum Car Videos
Custom Wheels
Vibrations Questions
  #11 (permalink)
Old 11 Apr 2006, 09:47 am
Jimbo Jimbo is offline
My money is on the retaining clips.Had afiend with the same problem.
Dealer tried to tell him that he had a broken axle.Took the clips off
problem went away.
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
  #12 (permalink)
Old 15 Apr 2006, 03:40 pm
chromer don chromer don is offline
Went to have my wheels rotated and balanced today. I was also having steering wheel vibrations between 60 and 70 mph. Told them about the retaining clips, sure enough they were there. They removed them no more vibrations. Thank you gentlemen !! Love this Form
  #13 (permalink)
Old 15 Apr 2006, 04:25 pm
Striker's Avatar
Striker Striker is offline
problem went away.
So do I... (not my money on but I had the same problem)
  #14 (permalink)
Old 25 Apr 2006, 11:42 pm
tony944 tony944 is offline
I found out what was my problem. The shop in Florida where i bought the car charged me the money but did not balance the tires and did not do wheel alignment. Interesting they charged me to do front and rear alignment, but I heard that on PTs there is no rear alignment. Anyway, I balanced the tires here in Atlanta and it is back to normal. Thank for all your help...
  #15 (permalink)
Old 26 Apr 2006, 07:33 pm
bobs turbo pt bobs turbo pt is offline
glad its fixed !![?]
  #16 (permalink)
Old 26 Apr 2006, 08:06 pm
purple04 purple04 is offline
Glad to hear you got it fixed. Make sure you don't do business with the first shop and DO use the second.
By the way, for future information, the PT and most other FWD cars don't have alignment (Caster, Camber & Toe) like you may be used to. While all can be measured (along with SAI {a next-level thing}), only the toe is adjustable. If any of the others are off, it's usually due to damage or wear (or modification=lowering). The front and rear should be checked if tire wear, other problems or damage is suspected. The rear alignment can be adjusted using shims between the axle and the spindle. This is not normal, but can be done. The front caster and camber can be changed too, but usually this is beyond what is needed for a stock, undamaged car.
  #17 (permalink)
Old 02 May 2006, 10:33 am
There is, needs shims to do - I whacked a pothole and needed rear and front...
See Purple04's post.
Glad you found the problem.
  #18 (permalink)
Old 12 May 2006, 09:59 pm
Supercharged Supercharged is offline
Send a message via AIM to Supercharged
You guys FUkin ROCK!!!
I have been dealing with vibrations on my PT for 2 years.
First, got hub rings. Helped allot but still had vibrations
Then got new tires. Got rid of the road noise.
Finally took the wheels off and found those retaining rings and now its fine. I love it..
Thanks for your info guys
Steven
98 Grand Prix GTP
Mods-I have some
01 PT-Pimpin it our for Mom
[IMG][/IMG] 01 PT
Pimpin it out for mom
vB code is On
Good vibrations KingKole02 Sound and Security Forum 0 14 Jun 2006 08:03 am
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
Yet more Stage 1 Questions mike257 Stage Turbo Kits 4 09 Mar 2006 10:59 pm
A couple of questions -- general detailing ?'s Cruising Mike The Detail Shop 3 16 May 2005 12:16 am
Boost Controller and Gauge Questions Dalite Turbo Performance 13 14 Jul 2003 01:20 pm
  Problem Mortgage | 0 Credit Cards | Debt Loans | Credit Report | Myspace Layouts
