Poping on left turn.
Old 03 Jun 2006, 05:34 pm
Default Poping on left turn.
See other posts but didn't find the solution or problem. Have a popping noise on sharp left turnes or when I'm turning left and go over a bump or alot of gas turning left. Can feel it in the steering wheel and sounds like it's coming from the left side. Did take a look at the tie rod ends and they don't seem to be faulty but I've not dealt with these or this problem before. Anyone know what the problem is or might be.
Old 04 Jun 2006, 03:01 am
Send a message via AIM to TurboCruiser13
My first response would be CV joints. Check the boots to see if there's any rips or tears or holes in them...if anything gets up in there it's pretty much over for your joints.
Old 05 Jun 2006, 10:51 am
Check your upper strut mounts first, but since the 'popping' only occurs on hard left turns (which significantly loads the RIGHT side suspension) have a look at the lower right control arm bushings as well. It's not uncommon to have the rearmost bushing fail to the point that you can readily see the rubber being squeezed from the joint.
Brian
\'03 5-speed S2 Dream Cruiser #1582 w/MP Stage 1 & BOV. Plastic Intake Manifold, rear Eibach springs and Supertrapp axle-back exhaust.
Crane 8.5mm FireWires & Champion Copper Plus plugs, K&N drop in filter. Chrome Plastic AMX TTAB pipe.
(Metro Detroit Area)
Old 05 Jun 2006, 02:56 pm
OK, it doesn't have to be at any speed just turn the wheel far enough and it'll pop, sometimes louder then others ofcourse. Now on the CV Joint? what other problems if failing will this cause or tell since it's been doing this for months now, I assume if this damages another part that part is going to be toast as well. I only know what I've changed or fixed when it comes to cars, lowering is all I've ever done in this area.
2003 Silver GT Auto Stick
MODS:dual ram-air hood, flames, carbon fiber interior kit,dvd nav tv tuner 7\"touchscreen, Fosgate 4 channel amp, 12\" dual subs with LED box, mb-quart modual speakers, windshild visor, leather racing seats, Goldline springs 3\"drop, Tokico shocks, BOV, C.F. tail lights, and more. Need to install xeon side skirts, rocker pod guages.
Old 05 Jun 2006, 07:52 pm
i would say cv joints, they always make noise when they are shot
Old 29 Jun 2006, 10:25 pm
Should I expect it to get worse with time. The loudness and feel three the s-wheel varies but shouldn't the popping start to multiply. I've delt with it for about 8k or more miles. Almost thought it was gone for a couple of days but wouldn't you know it would pop itself back when it pleases. Consistent that it does pop but sometimes louder than others and haven't narrowed down if angle, speed, or surface condition makes any difference.
Old 05 Jul 2006, 09:11 am
You might want to have the Rack & Pinion checked out. Mine gave me a pop or clunk noise thay was faint at first but grew worse over time. It finally got to where it did not want to turn left when first starting out. Took it to a dealer (while on vacation in FL) and they replaced the rack. Cost a bit over 700 bucks but it cured the problem.
Old 07 Jul 2006, 05:40 am
thegoldpt's Avatar
Send a message via MSN to thegoldpt Send a message via Yahoo to thegoldpt
Could it be your CV joints?
Old 07 Jul 2006, 11:31 am
I found this -
03-006-04 09/15/2004 Powertrain:Axle Assembly:Axle Shaft -
Front Hub/Half Shaft Click/Pop Sound.
But I don't have the text of the Tech Service bulletin...
Check that the rubber boots are okay on the driveshafts.
Noise in front when making left turn; not right Runkle Wheels, Tires, Suspension 2 12 Feb 2007 01:04 pm
Turn Signals Not Working Indynick General PT Cruiser Discussions 9 15 Sep 2004 02:25 pm
Turn signal & stop light gonzomania General PT Cruiser Discussions 12 25 Apr 2004 01:18 pm
Granada Hills, CA Christmas Parade -- Dec. 7th. Basset Hound Western PT Forum 0 02 Dec 2003 01:25 am
02 PT Drifts to the left. kdioquino Tech & Performance Forum 3 09 Apr 2003 11:59 am
