2004 rims
Old 11 Jan 2007, 07:29 am
Default 2004 rims
G'day - this may sound like a stupid question, but does anyone know how the remove the stock chrome looking rims from a 2004 Cruiser. I've remove the wheel nuts and tried to remove the rim but it wont budge. Is there something I'm missing - some special trick?[xx(][:I]
Old 11 Jan 2007, 10:02 am
If you have the lugs nuts completely off, there should be nothing holding the wheel on. Give the tire a good shove/kick and that should loosen the wheel. The back of the wheel is just stuck on the hub.
Old 11 Jan 2007, 10:58 am
Welcome.
Crewzin is 100% right. Kick the tyre, whack the backside with a rubber mallet - there's just a but of corresion sticking the wheel to the hub. When you get it free, you'll see the outline of the wheel very clearly on the hub.
Have you joined:
http://www.ptcruisers.com.au/forum/
Old 11 Jan 2007, 05:42 pm
Thanks guys, I'll give it a go.
Old 12 Jan 2007, 12:15 pm
This is a known 'feature' of alloy wheels and steel hubs. The dissimilar metal electrolytic reaction forms corrosion and causes them to chemically weld together.
If you are lucky a few kicks will break things loose.
Put it on JACKSTANDS, not the Toy Jack that Chrysler included with the car.
Otherwise you might need professional help (go to Tire SPECIALIST...Not BJs, Not Sears, Not Your guy down the corner who keeps your engine running like a swiss watch.)
And the Moral of our story:
This 'bondage' will not have time to happen if you Rotate Your Tires every 6000 miles.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 20 Jan 2007, 04:18 pm
or add some anti sieze to the hub [|)]
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 20 Jan 2007, 05:24 pm
sit on your but a give a kick to the tire left side then right it should let loose
Old 26 Feb 2007, 11:48 pm
D. D. is offline
If all else fails... slightly loosten the lugs. Very slightly, perhaps an eighth of an inch (or about 3mm), lower the car and take it around the block. The weight of the car should do the work for you. It beats beating up on the wheels.
2004 GT Stock 17" Chrome Rims & Tires for Sale PTGT_Boy Classifieds: For Sale/Trade 13 17 Nov 2008 11:43 am
Rims please note KingKole02 Tech & Performance Forum 11 27 Feb 2007 01:46 pm
PT rims 2004 6 spoke OEM w/tires shapemaster Classifieds: For Sale/Trade 1 27 Oct 2005 05:52 pm
2003 PT Turbo 17" chrome rims and tires *MINT* GLH_TC 16V Classifieds: For Sale/Trade 2 02 Apr 2004 12:11 pm
New Incentives on 2003 and 2004 Models skylight PT Cruiser News and Rumors 3 15 Oct 2003 12:26 pm
