Age old question (again) max tire size stock wheel
Old 27 Jun 2003, 12:09 am
Default Age old question (again) max tire size stock wheel
After three years and 40+K miles it going to be time to replace the stock goodyears on my PT LE. I line the stock chrome 16" wheels but I am a great fan of BIGGER TIRES. So, for those of you who have actually done it... what is the max tire size that will work on the stock rims on a non-lowered PT? I was thinking of Sumitomo 225/50 16".
Thoughts? Recommendations?
Thanks
Old 27 Jun 2003, 03:14 am
And, for the GT crowd, same question for the stock 17s.
\'03 Silver Turbo, 5-speed, tinted front windows, gutted air box, K&N Filter, weather strip removed, second horn... Cool mods coming soon.
Old 27 Jun 2003, 01:36 pm
I had Sumitomo HTR 225/50-16's put on stock chrome rims last night.
They look, feel, and ride 1000% better than the goodyears.
As for sizes 225 in the front are max from what I can see and 245 in the rear. There is a real clearance issue due to the offset of the stock wheel. take a look at NTB.com for a nice comparison of different sizes.
G (Nitro) 01 LE with color shifting flames (painted not stickers )
and a few other items added, but to many to list.
Thanks
Old 01 Oct 2003, 01:36 pm
225/50-16 tires are larger than chrysler recommneds. Any safety, supension wear or speedometer issues with these tires?
Old 01 Oct 2003, 02:46 pm
For the GT it's 215/50/17, Jody has a pic of those mounted on stock GT wheels here
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=2227
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 08 Oct 2003, 11:52 pm
[?]BobM_CT
I decided I wanted larger tires than the Cruiser came with.
I realized the best way to make the tires look larger is to use smaller wheels.
I ordered some 15" smoothies from Moss motors and then bought my tires to match the "HOT ROD" look I wanted. The front tires need to have the same circumference as the manufacturers tires. So the fronts are 205/60r15's but the back tires are 235/60r15's. Sets it up a little more in the rear.
I could even tell it had a little more rake, when I got in the car it seemed like the seat was elevated in the back.
The ride is smoother also. I guess its because the sidewall is taller allowing more absorbtion of the smaller bumps in the pavement.
Just make sure when you do order tires that you get them wide enough to make it not look skinny compared to the tall height.
But not too wide to fit under the fender wells.
Good luck and keep us posted...Pics' and all.
nice shine, huh.
Cruisergeo
My Website is
http://cruisergeo.tripod.com/
Old 10 Nov 2003, 05:51 pm
I ordered some 15" smoothies from Moss motors and then bought my tires to match the "HOT ROD" look I wanted. The front tires need to have the same circumference as the manufacturers tires. So the fronts are 205/60r15's but the back tires are 235/60r15's. Sets it up a little more in the rear......
just curious.....any problems with this setup yet? I believe you have a LE with ABS/traction control and the above combination represents about a 5% difference in front/rear diameter relative to a recommended 3% cutoff for the ABS system to work right. (my guess is the 3% limit is being conservative)
Old 11 Nov 2003, 09:18 pm
Send a message via AIM to FlowRW
The largest recommended tire for the stock rim is in fact 225 50 16. I have had my Sumitoma HRT's for about 5 months now. What fantastic riding tires. I had no idea the orginal Goodyears were the crap they were until I had these put on. The neat thing about these HRT's, they have a recessed bead that your rim rides in and it protects the rim should you scuff up against a curb.
<b>http://www.CarolinaPTCruisers.com
Rick & Susie Flow
Charlotte NC
ZZ Taupe\'s online photo album
http://www.carolinaptcruisers.com/ZZTaupe.htm</b>
Old 21 Nov 2003, 02:53 am
Cruisergeo, Really like that look alot! Very "Old School" haha
Tire size on turbo wheel. tomcruz Turbo Wheels/Suspension/Handling 10 29 Jul 2008 07:18 am
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
I had it with this F ing wheel or GYear tire! Ctown General PT Cruiser Discussions 3 29 May 2005 08:24 pm
Question: Wheels and PT Wheel Wells PTGT_Boy Turbo Wheels/Suspension/Handling 42 13 Sep 2004 11:46 pm
18x8 rims what tire size best dfunkdj Wheels, Tires, Suspension 4 15 Apr 2004 04:04 pm
