PT Cruiser Forum Car Videos
Custom Wheels
Maxspeed Springs- Input needed ASAP
Old 08 Aug 2007, 12:36 pm
JCsGTPT JCsGTPT is offline
Default Maxspeed Springs- Input needed ASAP
Anybody currently running, or had in the past, maxspeed lowering springs?
If so, do you / did you like?
Lowering quoted as 1.4 in the front and 1.5 in the rear. Is this the results you got after install? Seems this would minimize the rake and not go too low which I would be interested in.
Did I read somewhere that the Mopar springs are manufactured by Maxspeed?
Old 08 Aug 2007, 01:27 pm
CREWZIN CREWZIN is offline
Default Re: Maxspeed Springs- Input needed ASAP
Can't reply as to MaxSpeed springs as I have a Eibach's but almost all lowering kits drop the rear lower than front to get rid of most of the rake.
Old 09 Aug 2007, 12:16 pm
R3dWhitNCrz R3dWhitNCrz is offline
Send a message via AIM to R3dWhitNCrz
Make sure you read through the suspension forums for the Turbo too, alot of information about springs in general. Be sure to upgrade shocks and anything else to make it work right the first time. I am working on my 5th change. I started with Gold line and stock shocks/struts. Then switched to Sachs struts. Then changed to eibach and sachs, only to replace sachs with Tokikos, now I'm trying to figure out the next/best move from there. Do it right the first time, you may have to spend more money but you won't be like me and replacing parts all the time. Good luck.
R3dWhitNCrz
http://mysite.verizon.net/vzepobb2/
Old 27 Aug 2007, 05:10 pm
NMdesertracer's Avatar
NMdesertracer NMdesertracer is offline
I bought those for my car. I only put the back springs in for now. Becuase im running 18" rims. Car sits level.
2002 Cruiser,Kenwood headunit,Fosgate amps & Speakers. 10,000K HID lights
Old 28 Aug 2007, 11:25 am
Taggert_LOA's Avatar
Taggert_LOA Taggert_LOA is offline
Send a message via AIM to Taggert_LOA
I'm running just the rears with the stock shocks and it works fine, it levels the car out perfectly.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
vB code is On
Cutting Springs...... Wicked_PT Wheels, Tires, Suspension 6 19 Dec 2005 11:45 am
Lowering springs installed. Espresso Wheels, Tires, Suspension 2 10 Jun 2005 11:27 am
Springtech, Maxspeed, Intrax lowering Springs A.C. Wheels, Tires, Suspension 5 07 Apr 2004 10:45 am
  Personal Loans | Credit Cards | Blind SQL Injection | Final Fantasy Soundtracks | Loans
