Poll: Wheel Bearing Replacement
  #111 (permalink)
Old 28 Dec 2009, 12:40 pm
Default Re: Poll: Wheel Bearing Replacement
Its not too bad of a job if you have decent tools like press, pullers, big bench vise etc. Took me about 8hrs to do both sides
Subject vehical is a 2007 base sedan, Auto, 2.4 here are a few pics...
Exploded view of hub assembly
Remove caliper and rotor, hang the caliper up out of the way...
undo tie rod, remove lower ball joint pinch bolt/nut, strut to knuckle bolts, remove driveshaft bolt and remove knuckle
Replacement bearings...about $120cdn at Napa
After the hub is pressed out of the knuckle/bearing you will need to remove a portion of the bearing shell that remains, here is the hub after the bearing shell has been removed
Here is the knuckle with the new bearing pressed in, don't forget to reinstall the retainer (not shown here)
pulling the hub in through the new bearing, you could also press it on.
then its a matter of reassembly, use a new cotterpin and make sure all fasteners are tight, give the brakes a feww pumps before moving vehical to reseat pads and go for a road test. This is the first time I have driven mine with quiet bearings...I can even hear the radio.
  #112 (permalink)
Old 28 Dec 2009, 05:44 pm
fastdel's Avatar
Send a message via MSN to fastdel
thats a good step by step guide
very helpfull
i did mine a few mnths back and the bearing was well stuck in
in end had to be put in a very heavy duty press @ a local engineering workshop
it must be one of the widest wheel bearings ive had to replace so far
my bearing cost me over £60 gbp
ALSO KNOWN AS JCCC
  #113 (permalink)
Old 28 Dec 2009, 07:46 pm
Right front @ 114K. Bearing was around $50, took the knuckle off and had it cleaned up and pressed in for another $30 at a machine shop.
  #114 (permalink)
Old 11 Jan 2010, 11:25 pm
I've done 4 so far.... first round at ~85k and ~95k, second round at ~150k and ~165k. Glad I purchased a 40ton shop press from harbor freight ($160 at the time), its been useful. I am not a fan of this car, I'll get 200K out of this like all my cars but it wasn't fun. My concorde on the other hand has 251K and runs like a champ. The key is never changing the tranny fluid
FYI, I'd like meet the intern engineer that designed the front PTcontrol arms (specifically "the bushing") kick him in the jimmy and revolk his PE license.
  #115 (permalink)
Old 15 Jan 2010, 12:51 am
2002
Finally replaced the screaming bearing I had at 100K. After 5k of listening to it I could not take it anymore.
After driving a half mile away from the shop I wondered why I waited so long. I could actually hear the road noise now....amazing
But how long are they going to last this time around?
  #116 (permalink)
Old 16 Jan 2010, 10:51 am
My 2003
165,000
  #117 (permalink)
Old 17 Jan 2010, 04:34 pm
VNT's Avatar
VNT VNT is offline
Who says he has a PE license which doesnt mean jack anyways. The PE's I work with in my current job couldnt hold a candle to the design engineers I used to work with.
anyhow you should kick the bean counters, they dictate the cost which impacts the design choice and the vendor used.
  #118 (permalink)
Old 28 Jan 2010, 01:46 am
2004 GT
44000, left side
  #119 (permalink)
Old 29 Jan 2010, 11:12 am
767skyking's Avatar
2006 Base
41K, Right side
  #120 (permalink)
Old 29 Jan 2010, 01:39 pm
2003 GT 87K both sides plus ball joint. Had it done at the local Tire Tracks for $500.
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
CV shaft after hub and bearing replacement? 2004PTGT Wheels, Tires, Suspension 9 17 Jul 2008 06:51 pm
axle nut torque/ wheel bearing problem 2tonSS General Turbo Discussions 3 28 Aug 2007 07:38 pm
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
