Poll: Wheel Bearing Replacement
  #31 (permalink)
Old 02 Oct 2008, 04:45 pm
Send a message via MSN to coco1476
Default Re: Poll: Wheel Bearing Replacement
88000 km and everything is still all good, unless the previous owner had the bearings changed but he never told me.I check my car once a month to check if everything is allright
2004 pt none turbo
  #32 (permalink)
Old 02 Oct 2008, 06:46 pm
loxmith's Avatar
Originally Posted by 2004PTGT View Post
Just taking a poll on whom had to have their front wheel bearings replaced? Please post MY and Mileage.
I'll start, 2004 PT GT, 41k.
Right about the same for me...04 GT, 44k
  #33 (permalink)
Old 02 Oct 2008, 07:39 pm
digitalpinscruiser's Avatar
Send a message via AIM to digitalpinscruiser Send a message via Yahoo to digitalpinscruiser
wow this thread is creeping me out I am at 23000 miles never had them replaced...
2007 PT Cruiser Touring Edition
  #34 (permalink)
Old 02 Oct 2008, 08:30 pm
nalati's Avatar
04
Left Front @ about 49K, 58K on the Right. Also Tie rod's @ 54K.
Front breaks @ 37K and Last But Not Least a seal on the Trans @ 34K, Covered Chrysler.
Question:
Anyone having trouble with the Auto Door Locks, @ about 28K my Doors would not Un-Lock (I was still inside), Chrysler said it was a defective switch!
  #35 (permalink)
Old 02 Oct 2008, 09:57 pm
Not being a mechanic guru, how would you know when you need wheel bearings replaced? Sorry if I'm kinda off topic... i have a 2003 with 120+K miles, maybe the previous owner had it replaced.
  #36 (permalink)
Old 03 Oct 2008, 12:34 am
nalati's Avatar
AstitchINtime
First time I had a noise at HW speeds and when making a sharp Right Turn, 2nd time same type of noise (But this time it was the other side).
The cost was $625 first time and $400 2nd.
  #37 (permalink)
Old 03 Oct 2008, 08:11 am
DJmart's Avatar
Send a message via AIM to DJmart
Do you need a bearing press for these wheel bearings?
To my understanding the 2001 does not have hubs, just single bearings.
Easy without a press?
  #38 (permalink)
Old 03 Oct 2008, 02:04 pm
loxmith's Avatar
With the Mrs cruiser it was a rubbing sound coming from the left front wheel.
  #39 (permalink)
Old 04 Oct 2008, 12:10 pm
Thanks Natali and Loxsmith - I so hope that the previous owner had to deal with the wheel bearings. As far as I can tell, I don't hear anything.
  #40 (permalink)
Old 01 Nov 2008, 08:26 pm
I just bought a 2002 with 106K miles, and replaced both. I have owned a number of FWD chrysler products. It seemed like there were a whole lot of issues with 82-85 wheel bearings, and went away. We owned two neons that ran 168, and 190K miles without having to replace them. I am suprised by the responses here. They may be using China crap bearings, rather than SKF or some other reputable brand.
Fortunately, I built a wheel bearing puller for the old k-car stuff and works fine on the PT. I can do it myself without wrecking the alignment. You just have to disconnect the lower ball joint, pull out the axle. I can make a posting if someone is interested.
Regards,
XT_laser
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
CV shaft after hub and bearing replacement? 2004PTGT Wheels, Tires, Suspension 9 17 Jul 2008 06:51 pm
axle nut torque/ wheel bearing problem 2tonSS General Turbo Discussions 3 28 Aug 2007 07:38 pm
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
