Poll: Wheel Bearing Replacement
  #51 (permalink)
Old 14 Jan 2009, 08:17 am
oldcoach's Avatar
Default Re: Poll: Wheel Bearing Replacement
I have just started getting what I thinks is a rumble from the right front bearing. I hope I can make it through the winter and replace the two front bearings and do the control arms and sway bar rubber replacement with the poly this coming spring. I have a 02 with 77K
02' Black Woodie Limited Edition Drop in K&N Air Filter w/air box mod. 06 tail lights, Limo tint all around, orange LED interior, Mopar 8 inch sub, Stull side pipes. Silver stars upfront, a little chrome
  #52 (permalink)
Old 14 Jan 2009, 09:41 pm
at 35k there should be warenty left on that thing unless it is over the age limit
  #53 (permalink)
Old 17 Jan 2009, 04:24 pm
djdownhill's Avatar
2007 Touring with 23500
I just got back from the Dealer and they had to do the right side Wheel and Hub Bearings.
No Charge though...........
My Geek Toy! <--It gets 10 MPG
^ Click and get maXimus ^
  #54 (permalink)
Old 17 Jan 2009, 06:05 pm
Default Wheel Bearing Replacement
I have an 02 that needed to right front bearing at 75K. Luckly for me I was able to do all of the grunt work myself. I disassemebled the Knuckle from the rest of the car. A friend of mine has a press and a bunch of adaptors to press out the old and press in the new.
It only cost me the price of the new bearing and 6 pack.
These PTs are pretty cool.
-jgclark
  #55 (permalink)
Old 23 Jan 2009, 12:06 am
We've got an 03 PT Limited with 67k miles on it. Just replaced the drivers side bearing this week. Original one was Timken part and was dry as a bone inside. A new made in the USA Timken was $32 at the local parts store. I have access to a hydraulic press so it wasn't too bad a job.
I've seen that this is a common failure and tried to identify what's different between the PT and my older Mopars (many of which have gone over 200k miles on original front wheel bearings). The only difference I could find was that the PT does not use a seal between the axle and the back of the bearing. Not sure if this is allowing moisture into the bearing and causing premature failure, but it's the best theory I could come up with.
  #56 (permalink)
Old 24 Jan 2009, 01:29 pm
I think the bearings are around $45.00 is it that hard to install them?
Not a mech but that sounds out of line.
  #57 (permalink)
Old 28 Jan 2009, 02:38 pm
car- 2003 classic
mileage- 75,289
cost- 802.18 which by the way im not paying
doing all the work myself today and it shouldn't be that bad
  #58 (permalink)
Old 29 Jan 2009, 08:56 am
we bought our cruiser with 145,000 on the clock.Maintence sheet says bearings was replaced at 52,000 and not since.Bearings are still quiet at 154,658 and no problems.Did put pads and rotors in it last year for the heck of it.Probably will put sway bar links in it this spring and maybe back brakes(thanks Alex).Are you guys that are eating bearings up run a bigger,offset wheel/tire combo?Doing really tight turnarounds?
  #59 (permalink)
Old 29 Jan 2009, 04:51 pm
'03 NA, 5spd. 71,000 miles. Origional bearings and brakes all around. Only thing changed has been plugs and wires. But I gotta fix the fan/relay before summer.
  #60 (permalink)
Old 29 Jan 2009, 11:02 pm
2003 with 182k Replaced the front wheel bearings at around 95k. Bought the bearings online for less than $35.00 each. I replaced the left one and about a month later replaced the right. Both times it was about 2 hours from driving in to driving out.
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
CV shaft after hub and bearing replacement? 2004PTGT Wheels, Tires, Suspension 9 17 Jul 2008 06:51 pm
axle nut torque/ wheel bearing problem 2tonSS General Turbo Discussions 3 28 Aug 2007 07:38 pm
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
