pothole messed up steering
Old 23 Feb 2008, 10:36 pm
Unhappy pothole messed up steering
I hit a pothole doing about 40 on my way to work, and after that the car doesn't feel right. I used to be able to hold the steering wheel straight and the car would go straight, now the steering wheel seems to wobble randomly from side to side when going in a straight line, and I noticed a bit of vibration in the front. I searched the forums and it seems like the problem should be the tire, the rim, alignment, swaybar or bushings. Is there anything else it could be?
thx
Inferno Red '02 PT Limited
-stainless vertical grille, E&G stainless pillars, chrome antenna bezel, shaved badges, oval billet mirror, fuzzy dice, brushed door and console inserts, Eibach prokit springs in rear
Old 23 Feb 2008, 11:58 pm
Default Re: pothole messed up steering
bent rim or you knocked the balancing weights off.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 24 Feb 2008, 01:49 am
Cathy06PT's Avatar
Send a message via AIM to Cathy06PT
I got am 06 pt Convert and had to Have them check both front Axels, I had done the same thing and found out I needed both replaced at 22,000 miles....I also recently had both wheel bearings replaced (replaced at 37400 )...Have them check both things....ASAP! it's not good to drive on it like that if it is anything I listed.
Old 24 Feb 2008, 10:50 am
i agree with cartman
Anyone that has steering problems... Please post nbr10 General Turbo Discussions 38 02 Feb 2009 10:24 am
Power steering whine problem identified sawdust123 General Turbo Discussions 5 10 Dec 2008 07:24 pm
No Steering Wheel Lock on '04 Base Model BGCee Interior Accessories Forum 4 03 Jul 2007 02:10 pm
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
Click in steering column tcruiser General PT Cruiser Discussions 3 11 Nov 2002 12:25 am
  Recreation 2007 | Find jobs | WoW Gold | Myspace Background Generator | Discount Perfume
