QUESTION: FRONT END NOISE
Old 03 Jun 2008, 10:29 pm
Default QUESTION: FRONT END NOISE
I have a lot of front end noise when going over bumps. Anybody know what it is ? Bushings ? Control arms ? Ball joints ?
Any websites I can findout more ?. . . and findout what I need to do ?
Torontopt2
E: brm45@sympatico.ca
Old 03 Jun 2008, 11:10 pm
Default Re: QUESTION: FRONT END NOISE
without actually hearing the noise, no one can tell you exactly what it is. my guess would be worn out stabilizer bar bushings, worn out control arm bushings, worn out spring isolators, or something that has come loose. get the car up on ramps and check all bolts for tightness, and then inspect all visible bushings for wear (cracks, bulgeing, etc.). also check that the battery is secured, and that all underhood accesories are secured.
what year cruiser and how many miles?
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 04 Jun 2008, 09:01 am
oldcoach's Avatar
Cartman is right on the issue, this comes with a PT Cruiser, I need to replace bushings on my 02 this summer.
02' Black Woodie Limited Edition Drop in K&N Air Filter w/air box mod. 06 tail lights, Limo tint all around, orange LED interior, Mopar 8 inch sub, Stull side pipes. Silver stars upfront, a little chrome
Old 05 Jun 2008, 12:49 pm
AlexJB's Avatar
Send a message via Skype™ to AlexJB
I got replacement sway bar bushings for $25 from flea-bay, it made a hell of a difference to my clunking from the front, an easy job too, only took 40 mins to change em.
To be old and wise, you must first be young and stupid.
Old 17 Jun 2008, 01:34 pm
oldcoach's Avatar
Just a heads up on this issue!
I had a tie rod blow out last week, so I replaced the two outside tie rods with new TRW parts. I when I hit the bumps to and from work I do not get the old front end noise. So I would say take a close look at the tie rod ends!
Old 25 Jun 2008, 10:55 am
OCCrewzR's Avatar
I was just going to post to check the outer tie rods. They make a heck of a racket once they get 'loose'. Just grab it by hand and if you can rotate it back and forth with NO resistance consider replacement , if there is ANY 'up and down' movement replace immediately!
2001 Limited Edition
N.A./Auto
3/4 inch rear drop.
K&N Drop in.
InDash Pioneer DVD Stereo
Our Photography
front brake "tock-tock tock" noise! nacnudv8 Wheels, Tires, Suspension 6 12 Jun 2011 07:12 am
front suspension noise RaceWilson Wheels, Tires, Suspension 7 23 Apr 2010 07:12 am
New Front Strut Question Gottasmilealot Wheels, Tires, Suspension 3 21 Apr 2008 12:17 pm
Front Sway bar / suspension question.. 06PT General PT Cruiser Discussions 7 06 Dec 2007 10:33 pm
Noise in front when making left turn; not right Runkle Wheels, Tires, Suspension 2 12 Feb 2007 01:04 pm
