changing rear springs, possible in the driveway?
Old 08 Jun 2008, 07:51 pm
Question changing rear springs, possible in the driveway?
I want to lower the rear of my PT like many others have done and I was just wondering if you need any specialty tools to do it or could I do it myself at home? It looks like it wouldn't be too difficult but I want to make sure before I buy the springs. thx
Inferno Red '02 PT Limited
-stainless vertical grille, E&G stainless pillars, chrome antenna bezel, shaved badges, oval billet mirror, fuzzy dice, brushed door and console inserts, Eibach prokit springs in rear
Old 09 Jun 2008, 01:36 am
Default Re: changing rear springs, possible in the driveway?
its real easy. block up the front tires, then jack up the rear by the axle. place jack stands under a sturdy part of the body not attached tot he rear swing arm. disconnect the upper mounts of the rear shocks, then slowly lower the jack until you can wiggle the springs out. swap the isolators ontot he new springs and instal is the reverse of removal. took me less than 20 minutes from start to finish. love the new look.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 09 Jun 2008, 02:25 am
I noticed in your sig you have an 02, so you'll also have to disconnect your rear sway bar if you have one!
Regards,
Qman...
Old 09 Jun 2008, 06:25 pm
DJmart's Avatar
Send a message via AIM to DJmart
Funny, I had to JUMP on the axle to get it to drop from the car..... even with the shock unbolted from the top.
I also disconnected the sway bar i believe.
-DJ
Old 09 Jun 2008, 09:36 pm
PTmodrod's Avatar
Not a hard job, I did mine too. No issues at all. Just follow the advice the people before me gave and you'll be good.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
Old 10 Jun 2008, 08:38 am
AlexJB's Avatar
Send a message via Skype™ to AlexJB
almost off topic but...
Is there any camber adjustment on the back of the PT?
I'd like to lower also but If I have 2 people in the back (1 adult & 1 child) my 20's rub the wheel arch.
With a little negative camber this could be eliminated and leave a little room for lowering.
To be old and wise, you must first be young and stupid.
Old 12 Jun 2008, 05:18 pm
Got it done. here's pics. looks pretty BAMF. next on the to-buy list is wheels.
WTB: Rear Say Bar / Rear Springs for Base Model Maxxam Classifieds: Want To Buy 2 11 Mar 2008 08:22 pm
Rear Lowering Springs Only hodgecr Wheels, Tires, Suspension 4 18 Jun 2007 11:54 am
Wanted- Stock Rear Springs for an 05 GT Convertible cjloker Wheels, Tires, Suspension 7 19 Apr 2007 03:39 pm
rear springs skeeter1620 Wheels, Tires, Suspension 18 29 Jan 2004 01:43 am
Rear springs only sakigt Classifieds: For Sale/Trade 4 24 Dec 2003 01:31 am
