Front end noise
Old 16 Oct 2008, 08:12 pm
Question Front end noise
Hello everyone, I am new this forum but not new to PT Cruisers. I have a 02 Dream Cruiser but my question is on another Cruiser that I just purchased for another family member. My Dream Cruiser has 39K miles and the 03 I just purchased has 92K miles. There is a knock from somewhere in the front end when hitting bumps. I have been told that it's a good possibility the struts needs to be replaced. Any thoughts on this would be much appreciated. I have done most of my own work over the years but if it comes to specialty tools sometimes I just take it to a mechanic and let them do the work.
Any info will be appreciated.
Thanks,
mheff
Old 15 Nov 2009, 04:06 pm
Default Re: Front end noise
Hi,
I have been experiencing the same symptoms and from what i have read in the forum, the best guess would be to check on the conditon of the anti-roll bar bushings. Good Luck with your car!
Old 15 Nov 2009, 09:06 pm
Matt42's Avatar
Thanks,
mheff
If it seems like a "bonk" coming from somewhere near your feet, it could be control arm bushings. At 93 K miles it could be a lot of things, maybe all of them.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, 2004 PT Cruiser Base 5 speed, 2007 Chrysler T&C Touring
Old 15 Nov 2009, 10:51 pm
Bushings!!!
Old 16 Nov 2009, 01:22 am
Say it is bushings...can anyone list what they have spent on such repairs and their experience....just curious what i am facing on my 2003 PT TOURING with 91,000 miles...I also have rattle under my floor board and the seem to go through the center also....I will know more tomorrow when I have a mechanic look at it...
Just curious, about estimates...
Thanks!
Mike
Old 16 Nov 2009, 12:41 pm
Bushings themselves aren't expensive - it's the labor. A dealer doesn't replace the bushings usually, they sell you new part with bushings in place, and swap out whole part.
Old 16 Nov 2009, 02:15 pm
Squirt WD-40 or some other water displacement "stuff" around the hangers and see what that does. I took our other PT to the dealer and I think that is what they did, no more noise.
Old 18 Nov 2009, 12:37 am
Hmm... I'll have to try this in my GF's car. I thought it'd be the ball joints making that noise, but it doesn't really do it on turns. It's pretty much just with bumps. I'm still going to check out the ball joints though.
Old 18 Nov 2009, 10:20 am
Can someone take a picture or at least direct me in the proper direction as to where the control arm bushings are? I have a general idea of where I think they should be, but I don't want to get under there with the WD40 and not know what to "squirt".
Old 18 Nov 2009, 11:37 am
white's Avatar
Your noise could be lots of things. I just had my 04 GT in a shop to look at all of the frunt end stuff and everything was OK. I have a loud bang, once in a while when I hit a small bump. Only every couple of days though. They could not fine anything wrong. Said it might just be a body panel poping, no big deal. I had an 01 PT that broke a bolt on the frunt frame that made the same kind of sound that I replaced and everything was OK then.
E. White
2010 Black over Silver, Couture Edition
front brake "tock-tock tock" noise! nacnudv8 Wheels, Tires, Suspension 6 12 Jun 2011 07:12 am
front suspension noise RaceWilson Wheels, Tires, Suspension 7 23 Apr 2010 07:12 am
QUESTION: FRONT END NOISE TorontoPT2 Wheels, Tires, Suspension 5 25 Jun 2008 10:55 am
Front end noise rickandsandieu Wheels, Tires, Suspension 2 16 Sep 2007 10:57 pm
Noise in front when making left turn; not right Runkle Wheels, Tires, Suspension 2 12 Feb 2007 01:04 pm
