Grease Fittings or No Grease Fittings
Old 02 Feb 2009, 05:22 pm
Default Grease Fittings or No Grease Fittings
Does anyone have the real story on grease fittings? I can find no real documentation on the subject. I even called my dealership today and they told me there are NO grease fittings on a 2006 PT Cruiser.
The only problem is I have at least 2. I know I have 2 since I added grease to them this weekend. Are there more?
Why do so many sources say there are none?
Old 05 Feb 2009, 07:46 am
Default Re: Grease Fittings or No Grease Fittings
From Free Auto Mechanic.com:
Grease Fittings are almost a thing of the past. You will find that most all front wheel drive cars do not have any grease fittings anywhere on the vehicle .However, you will still find plenty of then on a rear wheel drive car or truck. They are usually located on the steering components and the drive shafts and U-Joints. Make sure these are greased at every oil change go cut down on pre-mature wear.
If your PT has the fittings, it's almost a "one-of-a-kind". Maybe the plant down in Mexico ran out of the originals and yours plus a few others were fitted with a different kind.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 21 Feb 2009, 02:34 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
was your car bought new or used?
i'm thinking they might be aftermarket ball joints, thus the grease fittings.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 24 Feb 2009, 11:38 am
crusierdad76's Avatar
well guys i looked on my 06 and there are at least 2 grease fitting on the fount ball joints or whatever they are called these days
Old 24 Feb 2009, 04:47 pm
All the original ball joints I've seen up here(canada) have plugs in both lower ball joints only.. Remove the plugs and install metric 45 deg nipples or you will be pulling the front wheels to lube them because of clearance problems. Thats the only 2 unless you use aftermarket replacement parts....DEBO
2001 PT Cruiser Limited Auto w/ full load 90k, K&N , Borla SS single exh, Progress fr & rear lowering springs
Old 01 Mar 2009, 03:48 am
i remember a article that if u have grease nipples to break them off and make it ungreasible..aparently that have enough grease from the factory and anymore will ruin somthing...i thought it sounded pretty damn retarded myself but that IS what i read...i think it was a tsb from mitchells or somthing
grease fittings RickMe Tech & Performance Forum 5 08 Nov 2015 11:21 am
grease fittings RickMe General PT Cruiser Discussions 1 07 Oct 2003 07:23 pm
