Regarding the clicking noise, double check your CVC joints. Make sure the rubber sleeves around them are not torn. I had another front wheel drive vehicle that made similar sounds until the CVC joints failed.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount. http://smg.photobucket.com/albums/v7...0PT%20Cruiser/ |
+1 on the possibility of a bad CV joint.A bad tire will cause a similar condition.
Changing the wheel bearings can be a problem as the bearing presses into the steering knuckle.If you have access to a press the job is doable.Replace the hubs at the same time. Clark |
Ok finally an update: I replaced the cv axle, and the clicking went away. However the humming remains and has gotten a bit louder recently (maybe just my imagination). Could the humming/drone/huge truck tire sound be anything but hub bearings? How can I tell for sure?
Does the humming getting louder when you turn one way or the other? Replacing the bearings isn't all that difficult. Remove the steering knuckle and take it somewhere to press the old bearing out and the new one in (usually runs $20/knuckle). While you're in there, I would check the control arm bushings and replace as necessary. If you change the bushings, get the car aligned afterwards.
1973 Barracuda 340/auto Modifications: Too many. 2002 PT Cruiser N/A 2.4L/5-speed Modifications: Boogers, Maddog 80% STS, Auto throttle body, Airbox modifications, Eibach Pro springs, Energy Suspension control arm bushings & motor mount inserts, disabled balance shafts. 1989 Caprice Wagon 307/auto Modifications: Lowered 2" front and rear, flat black paint, emblems and trim removed and filled, pinstriping, big 'n little tires. |
