Lube points under PT
Old 23 Jun 2009, 09:21 pm
Default Lube points under PT
Are there any places under the PT that require lubrication? I hear creeks/groans that sound like low pitch bed springs during low speed driving (or start/stop) and trying to figure out if there are certain points that need periodic lube. Also, any comments on changing shocks such as miles/kind. Thanks.
Old 25 Jun 2009, 06:56 am
Default Re: Lube points under PT
There are no lube points under the PT that I know of but after saying that, one owner did find lube fitting on the ball joints. There was a lively discussion about it and we think the previous owner had put them in, but from the factory there was none. The front bushings on both A arms have had to be replaced on numerous PT's. Check them out and see if there's any cracks or splits which would mean yours would have to be replaced also. The growning you hear might be the first sign of failure of those bushings.
The shocks are pretty easy to replace on the PT. It's the front struts that require special tools and if you've never done it before it's best left to a shop. The springs around the struts are under a lot of pressure and you can do yourself harm if your not careful.
As far as brands of struts and shocks, there's too many to recommend just one.
2000 PT. 100,000 miles, Original Owner
Old 22 Jul 2009, 01:19 am
Matt42's Avatar
Can the remains of the factory installed and broken off fittings be removed and replaced with zerks?
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, 2004 PT Cruiser Base 5 speed, 2007 Chrysler T&C Touring
Old 22 Jul 2009, 08:13 am
mopar_man's Avatar
This is coming from my friend who's managed a parts store for several years:
Monroe is a marketing company, not a shock-absorber company. They produce five levels of product: Absolute trash (Monroe-matic), garbage (Gas-matic), brand-new worn-out shocks (Sensa-Trac--if you ever see one of these cut open, you'll cry if you bought 'em), overpriced (Gas Magnum--identical to the Gas-Matic with nothing more than a larger oil reservoir which makes absolutely no difference), and relabeled versions with astounding price tags (Rancho). And I sell Monroe--as well as Gabriel, another brand of which I'm not overly fond but they're better than Monroe.
There are only four shock-absober companies that I recommend: KYB, Koni, Penske (be prepared for serious sticker shock), and Bilstein. Penskes are the only American-made shocks--or at least US-owned--of those four of which I'm aware,
Another friend who has been a master mechanic for even longer agrees. Tokico makes shocks for lowered vehicles and most guys on the Cruiser forums recommend them.
There shouldn't be any fittings on factory parts. They're all sealed units.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Old 22 Jul 2009, 08:52 am
tandt14's Avatar
If you are referring to the bushings on the lower control arms, yes they can be replaced. From the research that I have done, if your Crusier has "low" miles, they should be replaced instead of replacing the whole control arms. My PT is creaking and groaning going over bumps and it needs new bushings for the lower control arms. ptcrew.com has A LOT of info on this topic.
BTW, my car has a little over 49k miles on it.
Old 22 Jul 2009, 09:15 am
mopar_man's Avatar
Even if it has higher miles, it shouldn't need the control arms replaced unless they're cracked or bent. My car has 120,000 miles on it and I just did the bushings about a month ago.
1973 Barracuda
340/auto
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Floor jack lift points? oldcoach General PT Cruiser Discussions 8 15 Aug 2009 02:18 pm
Floor Jack Points on PT rszappa1 General PT Cruiser Discussions 8 18 Oct 2004 07:58 am
insurance on your points Punch Non-PT Discussions 6 03 Dec 2003 07:23 pm
Lube Points? MCM Tech & Performance Forum 1 19 Nov 2003 02:04 pm
BEST RPM SHIFT POINTS MEXICANPT Turbo Performance 8 08 Sep 2003 07:57 pm
  Free Anonymous Surfing | Wordpress Themes | Debt Consolidation | Find jobs | Cheap Digital Cameras
