What size Tirs and rims?
Old 24 Jul 2009, 12:26 am
Send a message via Yahoo to crudlife66
Default What size Tirs and rims?
I have a 2001 PT Cruiser base model,Inferno Red,clear pearl coat,factory wheels and tires.I am not good with car parts,etc,I want to buy some new rims and tires,nothin crazy expensive(1000)range,What size rims fit this model?
Old 24 Jul 2009, 01:18 am
808's Avatar
808 808 is offline
Default Re: What size Tirs and rims?
If you want to keep the Base Model specs and look, then the rims you'll be looking for are:
Offset: ~ +35 to +40
Bolt Pattern: 5x100
The Base Model tires are:
P195/65R15
If you want to completely upgrade them by "Plus Sizing," look for rims with the same offset and bolt pattern as above:
For 16" rims, you'll be looking for tires in this size: 205/55R16
17" rims: 205/50R17 or 225/45R17
18" rims: 225/40R18
19" rims: 225/35R19
The size tires shown are a base guideline to keep the overall tire diameter as close as possible to the stock diameter to maintain an accurate speedometer/odometer.
Of course, the larger rims you get, the more expensive it will be. Also, the larger the rims, the smaller the sidewall of the tires, so there'll be less protection for those rims and way less comfort for the ride!
Old 24 Jul 2009, 06:40 am
Travis2k7's Avatar
Yep that's what I run... Toyo Spectrum 205/55R16 Store
2006 Limited, Auto, 90k miles
Old 24 Jul 2009, 12:53 pm
As you can see by my sig and my gallery I went with 225/50/16 tire and thay fit well. My rims are made for a FWD PT and I get greater hndling.
Terrry
2005 PT Cruiser Convertible - Touring Edition - Black
Mopar Spoiler, Mopar Ground Effects Kit, 16x7 American Eagle Chrome 5 Spoke Wheels, Toyo Proxes 4 225/50/R16 High Performance Tires
Autotechnica Chrome Shifter & Autotechnica Chrome Shifter Kit, Sony Headunit
